automatic headlights on a 90 corvette
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81758
Printed Date: May 15, 2026 at 11:52 AM
Topic: automatic headlights on a 90 corvette
Posted By: wldtyng
Subject: automatic headlights on a 90 corvette
Date Posted: August 18, 2006 at 5:40 PM
! have a 90 corvette and i put 84 headlight motors in it the 84 is a three wire motor and the 90 is a 2 wire motor does any one have a idea on how to work this?
Wldtyng
Posted By: bellsracer
Date Posted: September 06, 2006 at 4:27 AM
The 90 is a reversable motor. + on one wire & - on the other motors one way; swapping signals reverses it.
On the 84, one wire is ground, one wire goes one way, the other reverses it.
This will need a relay setup. In order to get the right relay wiring setup, you'll need to know if the headlights return a signal that tells if they are fully up or down. If they don't, don't worry, a different setup will still get the job done. PM us once you know about the headlights. We can get the diagram setup for you then.
