LED door handle lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=82166
Printed Date: May 15, 2026 at 5:31 PM
Topic: LED door handle lights
Posted By: simulant
Subject: LED door handle lights
Date Posted: August 28, 2006 at 7:25 AM
Hi!
I've had this idea of installing sort of courtesy lights in the outer door handles. I want them to come on by unlocking the car and go off by opening the door/locking the car. I figure that impulse for "on" would come from alarm's "open" impulse to central lock, and "off" from "close" impulse and/or from the door pin. Connecting the relays in the middle is what has got me confused. All trigger impulses will be negative/ground. Can anyone help me figure this out? Thanks for any replies!
Posted By: caraudio904
Date Posted: September 09, 2006 at 3:57 AM
I see your from another country so lets see if we can common ground our terms. Because I don't really understand but from what I can understand your not far from the right track. Use a relay and you cound connect it to almost anything depending on the effect you want. You could use parking lights, door locks. anything, Really what kind of alarm do you have?
Southern Stylez
Jacksonville, FL 32218
Posted By: Cameronjc
Date Posted: September 12, 2006 at 9:33 PM
If your alarm has a dome light feature, you could use that as well.
If it is already hookup up, changes are you can connect the door LED's right to the relay.
Posted By: ill-logix
Date Posted: September 22, 2006 at 11:10 AM
Take the open impulse from the alarm system and wire that to the coil of  a latching relay. I believe a diagram is provided on this site.  Use the normally open contacts of the latched relay to drive power to your leds.  Now wire a second relay coil to the door open signal.  Now wire one side of the normally closed relay  to +12v and the other to the supply side of latching relay coil.
- denotes wire
] [ denotes normally open contact
]/[ denote normally closed contact
O denotes relay coil.
****** denotes leds
+12 door open signal--------------------O-------------------------------------------------------GND
                                                              door open relay coil
+12 open impulse signal----------------]\[-----------------------------------------O-----------GND
                                                              door open relay contact                latched relay coil
+12v-------------------------------------------] [-------------------------------------******-----------GND
                                                             latched relay contact                door handle led
