Dome light supervision??
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=881
Printed Date: March 22, 2026 at 11:09 AM
Topic: Dome light supervision??
Posted By: naughtydog
Subject: Dome light supervision??
Date Posted: May 22, 2002 at 5:19 AM
i am in the UK and came across this phrase "Dome light supervision??" on this site - can anybody clarify what it means??
Is it just the connection to the door switch??
Also, the term hot and cold brake pops up  - is this just the connection to either side of the brake pedal switch??
Another one if I may, when fitting engine starters, how difficult is it to bypass the transponder immobiiser. I have seen kits on other sites for PATS and PASSLOCK and also a universal transponder bypass kit. Can anybodly enlighten me as to how they connect etc
Naughtydog
Posted By: the12volt
Date Posted: May 22, 2002 at 8:20 AM
Hi Naughtydog, "dome light supervision" is basically the same as "illuminated entry". "Hot and cold" side of brake refers to the constant 12V+ lead (hot) and the lead that rest at ground (cold) when the pedal is not pressed (or both leads on the brake switch). Installing a transponder/VATS bypass is not difficult and you can find many explainations throughout this forum. https://www.the12volt.com/installbay/search.asp?search=transponder&searchMode=allwords&searchIn=Thread&forum=0&searchSort=dateDESC&Submit=Start+Search
https://www.the12volt.com/installbay/search.asp?search=VATS&searchMode=allwords&searchIn=Thread&forum=0&searchSort=dateDESC
the12volt
