2003 chevy suburbanparking lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=90627
Printed Date: March 24, 2026 at 9:53 PM
Topic: 2003 chevy suburbanparking lights
Posted By: navyguy13
Subject: 2003 chevy suburbanparking lights
Date Posted: February 18, 2007 at 7:38 PM
Hey all I got replacement LED lights formy suburban cause I wanted them plus my stock light was not working so I thought get new ones. I put in the new LED tail lights and when my truck is in park the right rear dose not light up. But for turn and brake its all good. So how can I figure this one out I already got pulled over 2 times and the guys at chevy said you got aftermarket its your fault. I tried to explain how it happened before I put them in but now they wont help me. Any help for wire diagrams and locations to meter would be great. I replaced all the fuses and that did nothing. All that is left is the relay inder the hood in the fuse box and the dude at Napa said there is no way one half of that relay would go out. So lets see what the tech's at the 12 volt can come up with.
Ronnie
Posted By: bellsracer
Date Posted: February 19, 2007 at 2:15 AM
Check the wiring itself and see if there is power going into the proper wiring. It is possible that one terminal could be loose or the wire may have gone bad. I would also check the socket too and see if there is power going through it properly.
