want to slow down rapid flash w/ leds?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97302
Printed Date: April 04, 2026 at 3:36 AM
Topic: want to slow down rapid flash w/ leds?
Posted By: MrMikey83
Subject: want to slow down rapid flash w/ leds?
Date Posted: September 20, 2007 at 4:08 PM
Hi everyone,
After reviewing the schematic, I have altered my blinker modules flash rate without the use of a power resistor.
Here is the original schematic. I have added the values in red of the components that are in the stock blinker for my '97 Cougar.
posted_image
Here is the component I added in place of R1. It is a 500K Ohm variable resistor. Mine is a single turn I got out of an old TV. I will probably replace it with something I can mount with a knob sticking out of the plastic case.
posted_image
~Mike
Posted By: KarTuneMan
Date Posted: October 17, 2007 at 11:10 AM
PM KPierson......he knows!
