key fob to control underbody neon
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98377
Printed Date: April 06, 2026 at 2:14 PM
Topic: key fob to control underbody neon
Posted By: marklorenzo
Subject: key fob to control underbody neon
Date Posted: October 27, 2007 at 9:27 PM
I have an underbody neon kit hooked up to my car. I have the toggle switch mounted under my dash, but i would love to have a wireless remote to turn them on. Anyone have any idea where to find a power source shut off and on wireless that can fit on a key ring? like a car alarm fob or lock/unlock.
Vroom Vroom
Posted By: KPierson
Date Posted: October 27, 2007 at 9:40 PM
Parts express used to sell a 3 channel RF receiver.  I'm not sure if they still do, but something like that shouldn't be hard to find.
Kevin Pierson
Posted By: i am an idiot
Date Posted: October 27, 2007 at 10:50 PM
Do you have an alarm on your car?   If so does it have an output on it?
Date Posted: October 27, 2007 at 11:48 PM
No i do not have an alarm hooked up.
Vroom Vroom
Date Posted: October 28, 2007 at 12:04 AM
https://www.smarthomeusa.com/Shop/Automation-Sec-Remotes/Item/PHR04/
https://www.smarthomeusa.com/Shop/Remote/Automation-Sec-Remotes/Item/PAT01/
might work, but how would you get power to it? could hide it under the dash.
Vroom Vroom
Posted By: aleckxs
Date Posted: October 29, 2007 at 12:23 PM
I don't think that X10 would work in a car. I use X10 at home and it's made for 110v applications. And having an inverter on in a car 24/7 would probably drain your battery...
Some models of LED/Neon underbody kits come with a wireless controller, but adding one might be complicated.
Installing an cheap alarm module could work. You wouldn't have to connect it completely, just the power wires and using the auxiliary output (like the trunk button) with some relays might be your best choice if you don't find anything that fits your needs. You might find one for 40-50 bucks (new or even less for a used module) on ebay or check your local classifieds.
Alexandre C.
2002 Nissan Maxima 6spd
Kenwood KDC-X891 HU
Kicker SX650.1 & SX400.2 amps w/SXRC Remote
Soundstream VGW-12 subs
Posted By: nkmcduff
Date Posted: November 22, 2007 at 3:31 AM
is your car a manual or automatioc?
