3 kicker comp vr 12s ported
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100029
Printed Date: May 06, 2026 at 2:55 PM
Topic: 3 kicker comp vr 12s ported
Posted By: sotexcustomz
Subject: 3 kicker comp vr 12s ported
Date Posted: December 14, 2007 at 11:12 PM
im ready to start my new box for my subs im trying to figure out what the port should be tuned to
the box will be mdf on 3 sides  with fiberglass face and 2 square ports
Posted By: aznboi3644
Date Posted: December 15, 2007 at 1:13 AM
what vehicle??
What amp??
How much space do you have??
What kind of output are you wanting??? smooth flat response or basshead bumpin??
Date Posted: December 15, 2007 at 2:04 PM
im going for spl ,i want slam    amp: orion 800x2
6 cf in the trunk i need to know what to tune the port to
ive figured a box 5.25cf
Posted By: boogienights
Date Posted: December 15, 2007 at 3:20 PM
Kicker's website will tell you all the specs for ports and cf for their cvr's.
Perfection is the only standard.
Date Posted: December 17, 2007 at 10:59 PM
how do i know what hz to set my ports to when building a box for my subs??
Posted By: stevdart
Date Posted: December 18, 2007 at 5:24 PM
If it were mine I'd probably tune to 29 Hz, but if you want SPL tune it to 40 Hz.  You have to have a subsonic filter set at 20 Hz to prevent overexcursion.  Two slotted ports each 6" X 4" (or equivalent square inch openings of 24 sq in each) for a total of 48 sq in.  Each port length is 11.3".   This is figuring with a net volume of 5.25 cu ft airspace (port volume is additional).
Date Posted: December 18, 2007 at 6:41 PM
and thats at 29 hz? im just trying to get the best sound overall and take some trophies
Posted By: stevdart
Date Posted: December 18, 2007 at 10:27 PM
No, what I posted is for what I said you should build for SPL:   Fb 40 Hz,  because you said you were aiming for SPL in your earlier post.  If you're competing you will have to have a lot of hands-on with this setup and work with it; probably work out a few different box arrangements and do extensive testing.  Do you know anybody who competes?  I don't do quick box workups on this forum with the idea that the user is going to win a championship with the box.  That can't be done by internet postings.
