Zobel on a 3 way box
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=1001
Printed Date: May 05, 2026 at 8:17 AM
Topic: Zobel on a 3 way box
Posted By: ensign_lopac
Subject: Zobel on a 3 way box
Date Posted: May 28, 2002 at 5:38 PM
I'm making my self some home speakers out of car audio speakers. I need to know what needs a Zoble stablizer.. is it just the high pass or is it any thing that has a filter on it? if it is everything how do you make the stablizer for a low pass and a band pass?
JAmes
Posted By: the12volt
Date Posted: May 28, 2002 at 7:18 PM
Hi ensign_lopac, add it to any speaker where the speaker's impedance substantially increases at a frequency within the range of frequencies you filtered to it to prevent the high pass filter from passing lower frequencies than you intented (impedance is relative to frequency). Most often you would use these on tweeters and maybe some small midrange speakers, but what speakers are you using to build your home speakers? Before you add any, check the manufacturer's specs for the speaker's impedance curve. They may not be necessary or if they came with crossovers,and they are needed, they may already contain them.
the12volt
