vas parameter discrepancy
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100593
Printed Date: May 06, 2026 at 6:05 PM
Topic: vas parameter discrepancy
Posted By: aznboi3644
Subject: vas parameter discrepancy
Date Posted: December 30, 2007 at 7:21 PM
Quoted from Pete Kulicki
"This is quoted from Pete Kulicki
"If you're referring to the T/S parameters, here's an in-depth rundown:
https://www.the12volt.com/caraudio/thiele.asp
The only discrepancy I see there is the explanation of Vas. It says: "Vas represents the volume of air that when compressed to one cubic meter exerts the same force as the compliance (Cms) of the suspension in a particular speaker."
That's incorrect.
Obviously, in order to "compress" a volume of air into one cubic meter, such volume would have to exceed one cubic meter. This would also mean that, if a woofer was to have any mechanical suspension at all, it's Vas parameter would have to exceed 35 cubic feet (or 1000 liters), additionally, a higher value would translate to stiffer suspension (which, of course is not the case).
Vas is, in fact, the volume of air that one cubic cubic meter is compressed down to in order to exert the same meters per Newton "push-back" as the woofer's mechanical suspension.""
Posted By: DYohn
Date Posted: December 30, 2007 at 9:55 PM
The definitions on this site came from the Rane technical library. It is far more important for a user to understand how to use the parameter than to know a precise definition, isn't it? ------------- Support the12volt.com
Date Posted: December 31, 2007 at 12:54 AM
yes it is...I totally agree.
I just wanted to let ya know DYohn :)
