2007 sliverado classic wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100639
Printed Date: May 06, 2026 at 9:37 AM
Topic: 2007 sliverado classic wiring
Posted By: ttruss01
Subject: 2007 sliverado classic wiring
Date Posted: January 01, 2008 at 1:42 AM
I have a 2007 Silverado Classic and I am trying to install an aftermarket radio but am having trouble with the wiring color code on the truck.  The truck is a basic truck with just a plain am/fm factory radio. Can someone provide some insite.
Wiring in the The dash
2 orange wires - one has a larger dia than the other
green, brown, blue (all have a lite color and dark color) - gray & yellow - these are all speaker wires correct?
Black - ground.
What I can not figure out is what do I connect the battey wire (yellow on the after market), ignition (red on after market), as well as the dimmer and Illuminaion wires from the aftermarket to?
Posted By: Alpine Guy
Date Posted: January 01, 2008 at 3:56 AM
Please tell me you didn't hack off the stock stereo plug! Thats a big no no!! Buy the proper wire harness adapter from your local stereo shop!
Posted By: Steven Kephart
Date Posted: January 01, 2008 at 11:44 AM
The Chevy trucks use a data-bus system which means you won't find an accessory in the harness.  It also means that if you don't use the proper GM module (probably around $80 at a local shop) that some of your vehicle electronics won't work properly.  Trying to go the cheap route and hard-wire one of these vehicle is asking for trouble.  The Peripheral part number you need is a GMCO.
If you still want to find those wires, you can find the power and ignition wires in the ignition harness running under the steering column.
Posted By: fknfbm
Date Posted: January 02, 2008 at 1:38 AM
If your looking for an ACC, which will be the red on the aftermarket radio, drop the panel under the steering column and underneath the light switch you will see about a 16AWG plain white wire. This wire will give you a true ACC but it will not retain the RAP (retained ACC power) until doors are opened.
Although I dont condone hacking the factory harness AT ALL, if you already have, the only things you will lose are all the chimes EX: low fuel, SES, door - headlights, things like that, and the RAP.
The orange will be 12v, the black - gnd,
        LF Speaker (+)          TAN
     LF Speaker (-)          GRAY
     RF Speaker (+)          LIGHT GREEN
     RF Speaker (-)          DARK GREEN
     LR Speaker (+)          BROWN
     LR Speaker (-)          YELLOW
     RR Speaker (+)          DARK BLUE
     RR Speaker (-)          LIGHT BLUE
