eclipse 3100 aux input
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100765
Printed Date: May 06, 2026 at 3:16 PM
Topic: eclipse 3100 aux input
Posted By: mcben789
Subject: eclipse 3100 aux input
Date Posted: January 04, 2008 at 9:19 PM
I recently purchased and installed an Eclipse 3100 CD player. I have an adapter that has one end you can plug into the rca outputs and the other end has a mini-jack male end (3.5 mm?). THIS is it.
I don't know which rca output to use. There is 3 to choose from: Hi, Mid, and Nonfader/low. I tried all 3 and none worked. I figured out how to turn the aux on but no sound comes out.
Any help would be appreciated because i have hardly any good cd's and I only use my ipod in my car.
Oh and would i have to purchase the whole iPod interface
I'm pretty much broke.
And I have also tried using different ipods.
Thanks guys,
ben
Sasquatch...
We know your legend's real...
Posted By: i am an idiot
Date Posted: January 04, 2008 at 9:34 PM
The 3 choices you mentioned are all outputs, they are to supply audio signal to your amplifiers.  Is there a set of cables that say AUX INPUT?   Or maybe a jack on the front of the unit?
Posted By: tedmond
Date Posted: January 04, 2008 at 10:06 PM
eclipse either does have the aux input on a 6 inch pigtail wire or the unit can be switched to aux through its data bus.
Posted By: mcben789
Date Posted: January 04, 2008 at 10:51 PM
There isn't an aux jack on the front or jack that accepts the 3.5 mm mini jack plug.
And what are you talking about data bus. And i have no idea what a "pigtail wire" is. Thanks for the super quick replies. It does though have one more plug in for like maybe hd radio, ipod interface, etc. I just don't want to have to purchase the ipod thing.
Sasquatch...
Posted By: forbidden
Date Posted: January 05, 2008 at 5:23 PM
The wire you have is not compatable with the CD3100. You need the specific AUX input adaptor plug from Eclipse, part # AUX105. It plugs into the back of the radio in the bus connector port, a round 13pin demale jack on the back of the cd player. The AUX plugs into that and then has a set of stereo rca inputs for whatever device you want to plug in.
Posted By: mcben789
Date Posted: January 08, 2008 at 4:44 PM
Got ya thanks guys.
Sasquatch...
