amp sub
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100810
Printed Date: May 06, 2026 at 3:13 PM
Topic: amp sub
Posted By: hirobo
Subject: amp sub
Date Posted: January 05, 2008 at 9:42 PM
Hello All
new to the forum, and looking for some help setting up my amp and sub. a friend of mine gave me an Alpine MRV-T407 amp, and an Alpine SWR-1042D sub. What would be the correct wiring setup from the amp to the sub? the back of the sub has quite a few connectors on it an im a bit cinfused. Also do you think that the amp will power the sub? im not looking for super thumping bass.
Thanks In advanced
Posted By: audioman2007
Date Posted: January 06, 2008 at 10:59 AM
How many connectors does it have? Im assuming it has 4. 2 on each side of the sub. They would be 1 positive 1 negative per side making it a dual voice coil sub. You also need to look to see what impedence it is. It should say on the bottom of the magnet.
Posted By: hirobo
Date Posted: January 06, 2008 at 11:53 AM
yes it is a dual voice coil. and the impedence is 4ohms
Posted By: jmelton86
Date Posted: January 08, 2008 at 1:11 AM
Wire the coils in parallel (both coil +'s to amp output +, both coil -'s to amp output -) to the amp. This will load the amp to 2ohms for max power output.
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
Posted By: hirobo
Date Posted: January 08, 2008 at 5:54 AM
this is how i have it hooked up now
posted_image
Date Posted: January 08, 2008 at 6:38 PM
https://www.alpine-usa.com/US-en/products/product.php?model=SWR-1042D
The sub has 2 4ohm voice coils on it. So, if you have them hooked up in series (like in the above pic) then that is 8ohms (4ohms of resistance plus 4ohms '' ''). The amp is loaded at 8ohms, which is twice the resistance of 4, so the amp will put out about 100watts x 1 (bridged) @ 8ohms, since it puts out 200watts @ 4ohm.
*****In my earlier responses I was thinking your amp was a 1channel -it's not- so I told you to wire the coils up in parallel for a 2ohm load which is not correct. I apologize for not doing the research posted_image. If you bridge the amp @ 2ohms, it will either not turn on or it won't last very long -possibly taking the sub with it.
Your only option is how you have it wired now.
OR, if you want the extra power (and only 3dB's in theory) then you can run 1 coil to the bridged amp. The amp puts out 200watts RMS bridged @ 4ohms, and each coil can handle 250watts RMS -a little more like 375 if you use one at a time, but we won't get into that because they'll handle 250watts each anyways. That's if you want the 3dB's, which most people can't notice anyway.
Big3 in 1/0G
1/0G to GTO14001
Posted By: greenbroncoguy
Date Posted: January 08, 2008 at 7:02 PM
nevermind, I read a post wrong...
Posted By: hirobo
Date Posted: January 09, 2008 at 4:54 AM
Ok so if i am following you correctly posted_image if I take out the Jumper wire that will give me 4ohms? sorry for my ignorance, and thank you for your help
Date Posted: January 09, 2008 at 5:02 AM
No. If you remove the jumper, there will be no connection. The positive wire goes into 1coil and the negative comes out the other, so if the jumper is removed neither coil will complete the circuit.
Just connect 1 coil of the sub to the bridged output from the amp. 200watts to a 250watt coil = nice...
Big3 in 1/0G
1/0G to GTO14001
Big3 in 1/0G
1/0G to GTO14001
Posted By: hirobo
Date Posted: January 09, 2008 at 4:45 PM
like this
posted_image
and it won't hurt the sub?
Date Posted: January 09, 2008 at 5:14 PM
I can't see you pic, but if you just wire the + of one of the coils to the + of the bridged output of you amp, and the - from the same set of terminals to the - to the - of the bridged output of the amp, you will be good.
Date Posted: January 09, 2008 at 8:04 PM
Yes, just like your makeshift pic posted_imageWhatever works!
Big3 in 1/0G
1/0G to GTO14001
Big3 in 1/0G
1/0G to GTO14001
Posted By: hirobo
Date Posted: January 10, 2008 at 4:28 AM
lol art wasn't my favorite subject posted_image
