97 pontiac sunfire wiring info.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100976
Printed Date: April 12, 2026 at 2:34 AM
Topic: 97 pontiac sunfire wiring info.
Posted By: amym1586
Subject: 97 pontiac sunfire wiring info.
Date Posted: January 09, 2008 at 4:21 PM
My radio wiring coming directly from the car were cut.
I bought this part..
https://www.installer.com/item/display_item.php?it=71-1858
and I'm trying to rewire the plug back on.
Constant 12V+     Orange
Switched 12V+      Yellow
Ground              Black
Illumination      Gray
Dimmer              Brown
Antenna Trigger Pink
Left Front (+)      Tan
Left Front (-)      Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Left Rear (+)      Brown
Left Rear (-)      Yellow
Right Rear (+)      Dark Blue
Right Rear (-)      Light Blue
I've done this all exactly as it says.
Conveniently, there are 2- yellow wires, 2- brown wires and 2-gray wires.
I have switched and switched back and done every possible connection I can think of.
From there, I then wired up a cd player. I can get it to come on but there is no sound whatsoever. I have checked and rechecked the wiring. I blew one fuse(the interior light) during the install but all the other fuses look fine. During the install some of the wires touched and the speakers in the back made a loud static sound. Did I blow the speakers?
Any help would be much appreciated.
Posted By: tedmond
Date Posted: January 09, 2008 at 9:15 PM
WIRECOLORPOLARITYLOCATIONposted_image
posted_imageBattery ORANGE (+) RADIO HARNESS
posted_imageAccesory YELLOW (+) RADIO HARNESS
posted_imageGround BLACK (-) RADIO HARNESS
posted_imageIllumination GRAY (+) RADIO HARNESS
posted_imageDimmer BROWN (+) RADIO HARNESS
posted_imagePower Antenna PINK (+) RADIO HARNESS
posted_imageLF Speaker (+) TAN
posted_imageLF Speaker (-) GRAY
posted_imageRF Speaker (+) LIGHT GREEN
posted_imageRF Speaker (-) DARK GREEN
posted_imageLR Speaker (+) BROWN
posted_imageLR Speaker (-) YELLOW
posted_imageRR Speaker (+) DARK BLUE
posted_imageRR Speaker (-) LIGHT BLUE
posted_imageRadio Security YES
cross referance your wires with the wiring chart i just gave you. Also make sure your speakers arent toast. Take a 1.5v battery and for pu tthe negative from speaker to negative on battery and postive to pos. touch the wires to the battery and hear or look for a crackling sound. That will ensure the speakers still work and function.
Posted By: amym1586
Date Posted: January 11, 2008 at 12:45 PM
Everything looks the same.
Tried the battery test with a definite crackling sound.
I really wanted to get this done by myself. posted_image
Thanks for you help.
Posted By: tedmond
Date Posted: January 11, 2008 at 1:04 PM
is your unit givein out any sound at all? check to see the vol is up and the fade is centered. did you just get the unit? or is from another car?
Posted By: amym1586
Date Posted: January 11, 2008 at 1:31 PM
no sound at all.
It's a brand new unit.
It came with a remote and I've tried muting and un-muting and turning the volume up and down. Still nothing.
Posted By: amym1586
Date Posted: January 11, 2008 at 5:20 PM
Drum Roll please..
Here comes the man I'm dumb speech!
My first step should have been to change that fuse.
You probably thought I was smart enough to have already done that..but nope. Apparently that fuse that said it was for the interior light also had something to do with the speakers..changed it and now everything is working!
Thanks so much for the help!
Posted By: tedmond
Date Posted: January 11, 2008 at 6:15 PM
gee, never heard of interior fuse being connected somhow with the speakers unless there is a factory amp which i dont see in any of my wiring charts. well nice to know you got it working .
