bi amp 6x9 suggestions
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101304
Printed Date: May 06, 2026 at 12:20 PM
Topic: bi amp 6x9 suggestions
Posted By: stuntinonabusa
Subject: bi amp 6x9 suggestions
Date Posted: January 17, 2008 at 10:49 PM
so i posted previously about my oem 6x9's blowing with the monsoon sound system in my 06 g6 gtp.  lookin at bi-amp speakers, i will be able to use the factory wiring to the crossover to the bi-amp speakers since i will be able to isolate the tweeter/mid range and woofer with factory wiring already in place.
what do you all recommend as far as a decent bi-amp 6x9??  i was looking at the soundstream sst6.9's or possibly the boston acoustic rx97's.  any input is greatly appreciated!!!!
if at first u dont succeed........ lower ur standards
Posted By: jmelton86
Date Posted: January 17, 2008 at 11:47 PM
You're going to be powering them via factory amp?! If so, why spend the money?
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
Date Posted: January 18, 2008 at 8:03 AM
using the factory amp to power these speakers is only a temporary solution until i can get the rest of the system together. i will be replacing everything in the car with aftermarket, but it isnt going to happen over night.
Date Posted: January 21, 2008 at 6:43 PM
Find out what the impedance of the factory speakers is, then check back.
When you do, we can see whether a 2 or 4ohm version would be best, if either will work at all. Unless someone knows the impedance of those factory speakers...
Big3 in 1/0G
1/0G to GTO14001
