Pioneer Deck and EQ in an GM opening?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10198
Printed Date: May 02, 2026 at 9:21 PM
Topic: Pioneer Deck and EQ in an GM opening?
Posted By: XtremeBumps93
Subject: Pioneer Deck and EQ in an GM opening?
Date Posted: February 28, 2003 at 9:27 AM
Okay I have a 93 Bonnevlle which I have a Pioneer DEH-P7300 installed already. I am intergrating a Pioneer DEQ-9200 Equalizer into the system. And i want to know if all this will fit in the Stock Radio Opening. The EQ is the same size as the CD player. Its a GM car with a double DIN so I think it will fit. If it does fit is there a company who makes a Install harness for such an application? Or am I going to have fashion something for my glove box? Please any info would be great.
XBumps93
Posted By: esmith69
Date Posted: February 28, 2003 at 10:20 AM
Are you sure it's a double-din opening?  I thought it was just a din and a half, in which case you can't add an EQ in there.  But when I went to crutchfield and entered in a 93 bonneville, it came up with two installation kits.  One of them is for the din and a half opening, and the other one is the GM multi-kit.  The multi-kit lets you add in an EQ so you might wanna take a look at that one.
Posted By: thepencil
Date Posted: February 28, 2003 at 11:14 AM
If I remember correctly I think it's just a din and a half myself. One other problem you might run into is the depth. You might need to used the extention on the kit, which will cause you a bit of a problem when you are fitting in your EQ.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Posted By: ViperATC5
Date Posted: February 28, 2003 at 2:00 PM
The GM Multi Kit by Metra only supports a single din style player without any modification. Two DIN size units will not fit into the GM din 1/2 opening
Date Posted: March 01, 2003 at 3:00 PM
Okay upon further inspection, the opening is a DIN and 1/2. i don't think its all going to fit. well it looks like some more XtremeBumps custom design work needs to be done. well thanks for the replys.
