power issue
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101983
Printed Date: March 25, 2026 at 9:25 AM
Topic: power issue
Posted By: efx3307
Subject: power issue
Date Posted: February 07, 2008 at 7:33 PM
Can i run an alpine type S sub with a hifonics 6006 amp or is it to much?
Bentley
Posted By: i am an idiot
Date Posted: February 07, 2008 at 8:03 PM
How old are you? What size is the Type S sub? What is the impedance of the voice coil(s) of the woofer? How much power is the amp rated at?
Posted By: jmelton86
Date Posted: February 07, 2008 at 8:20 PM
i am an idiot wrote:
How old are you?
Oh, man! I nearly choked!!! posted_image
I think i am an idiot thinks all young cats jack the gains all the way up. Well, it makes sense...
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
Posted By: aznboi3644
Date Posted: February 07, 2008 at 8:23 PM
"hear it.feel it.see it. XPLOD"
must be a young gun. You can run a tweeter on that amp...just depends on your settings
Posted By: efx3307
Date Posted: February 07, 2008 at 10:01 PM
haha anyway....the sub is a 12 with 2 ohm voice coils..amp is rated at 14.4 600 rms bridged or 150x2 rms...any idea on how much the gain should b turned up...quarter inch less than half way?
Bentley
Posted By: Walkercustoms
Date Posted: February 07, 2008 at 10:16 PM
Tune by voltage before clipping.
Posted By: n2audio
Date Posted: February 08, 2008 at 10:36 AM
the amp's gain is set relative to the HU's pre-amp voltage, but with a 300w sub you would definitely want to be conservative with the gain.
once you get it all wired, set the amp's filter switch to LP/BP, set the hi pass dial to ~20, the low pass dial to ~80 and the level to 6v.  Put in a cd that represents the typical style of bass you listen to and increase the gain until the sub starts to sound muddy - then back it off slightly.  That should give you a pretty good base line gain position.  You can reduce it, but don't go up much from that point.
If you use the bass EQ, don't use much.
Posted By: efx3307
Date Posted: February 08, 2008 at 1:38 PM
is 6v all the way down? I listen to a lot of rap an some hits pretty low and hard should i set the gain on one of these songs
Bentley
Posted By: efx3307
Date Posted: February 08, 2008 at 1:46 PM
if I set the gain correctly i should be able to run it bridged right? Thanks for all the feedback.
Bentley
