wiring subs confusion
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102144
Printed Date: April 30, 2026 at 5:57 PM
Topic: wiring subs confusion
Posted By: mazzasec
Subject: wiring subs confusion
Date Posted: February 12, 2008 at 10:16 PM
Well I am looking at this chart. And I am confused cause it says to go - to - but its a positive voice coil? can someone explain how this works! thank you
posted_image
Posted By: still_walkin
Date Posted: February 13, 2008 at 4:45 AM
you r saying there are to positives on one side sounds wrong or maybe you have the speaker turned the wrong way take a pic of the sub and we will go from there
1993 sdv
Alpine 4x6 6x9 5 1/4 swr-10d4
alpine v60
12.5 VGA flip down
Nettop pc w/10" touch screen
78nova
5-re audio 5x7 ,10" sub &
Xtx-500.5
Posted By: audioman2007
Date Posted: February 13, 2008 at 2:30 PM
Yea you probably have the sub turned the wrong way and its messing you up. The only other thing I can think of is that there are 2 positives on one side and 2 negatives on the other side, but I doubt that.
Posted By: stevdart
Date Posted: February 13, 2008 at 9:19 PM
The diagram you show above is an illustration.  It doesn't necessarily have the polarity of the coils in the exact locations as your particular sub does.  When drawing a diagram, you can put things anywhere you want to (just take a look at some of my diagrams ;#).  Just follow the wiring lines shown in the diagram and attach each end to the polarity the diagram shows.
Any coil will have both a positive and a negative terminal.  Make sure you first identify each set of coil terminals before you start connecting wires.
