finishing 3 way setup
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102690
Printed Date: May 06, 2026 at 2:55 AM
Topic: finishing 3 way setup
Posted By: Reeceddogg
Subject: finishing 3 way setup
Date Posted: March 01, 2008 at 3:14 PM
i've decided to make my own 3-way components since i have a lot of parts laying around. So far i have a MB QUART 3-way passive crossover, kicker impulse I57.2. what should look for to finish this off.
Date Posted: March 01, 2008 at 3:19 PM
i also have a pair of Oz Audio CS-3 crossovers that i could use as well.
Posted By: haemphyst
Date Posted: March 01, 2008 at 7:17 PM
Well, TECHNICALLY, without knowing what kind of "voicing" (i.e. padding, EQ, Zobel, etc.) is built into the crossovers, you really can NOT say what drivers you can connect to them. You may or may not get any kind of desirable response at all...
Who knows WHAT your final results will sound like. My bet is "crapola".
Best bet? Toss whatever idea you THINK you can do with those parts, and start fresh. Sell your crossovers AS THEY ARE on eBay to somebody that might actually have the OEM drivers, designed to work with those passives. Don't try to buy off the shelf drivers, and try to connect them to those crossovers.
