watts at 1.3ohm vs 1 ohm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102798
Printed Date: March 26, 2026 at 4:22 PM
Topic: watts at 1.3ohm vs 1 ohm
Posted By: Reeceddogg
Subject: watts at 1.3ohm vs 1 ohm
Date Posted: March 05, 2008 at 3:19 AM
What's a difference in power output from let say a 1500 rms @1ohm as compared to 1.34 ohms.
Posted By: stevdart
Date Posted: March 05, 2008 at 6:47 AM
You have to have another variable:  rated output at 2 ohms would work.   If in this case the 2 ohm output is rated 750 watts:  calculate the 1.34 ohm output by
  • find the difference in watts between 2 ohm and 1 ohm.  It is 750 watts.
  • 1.34 is one-third of the way from 1 to 2, so divide the difference of 750 watts by 3.  It is 250 watts.
  • subtract 250 from 1500 to get 1250 watts at 1.34 ohms.
  • if the impedance was 1.67 ohms, the calculated output would be 1000.
  • double-check your calculations by noting that when impedance goes up, power output goes down.
Of course, this is just for the sake of having numbers associated with impedance load and may not be true if tested.  If the case were that the amplifier was rated 1000 watts at 2 ohms and 1500 watts at 1 ohm (doesn't truly follow Ohm's Law due to amplifier's high current limitations), the results are derived the same way but would be viewed a little more skeptically.  That's where you could rightly say, "...somewhere between x and y...".
Posted By: haemphyst
Date Posted: March 05, 2008 at 9:33 AM
Not to mention the in-car insignificant difference in total output...
To even have an amp that TRULY doubles from 750 @ 2 to 1500 @ 1, the total output diffence in THAT case is only 3dB, meaning that you will have just about 1dB difference between 1 ohm and 1.34 ohms.
Posted By: jmelton86
Date Posted: March 05, 2008 at 6:24 PM
Meaning that it would be pointless to work the amp harder @ 1ohms VS 1.34ohms.
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
