problem with 5 channel amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103463
Printed Date: March 23, 2026 at 8:50 PM
Topic: problem with 5 channel amp
Posted By: martinisaac
Subject: problem with 5 channel amp
Date Posted: March 28, 2008 at 9:32 AM
Hi everybody.
I have a problem wiring my 5 channel VIPER 450.5 Amp into my 2007 toyota prius package #2. Here is a picture of my working setup (don't worry, it won't look like that when it's done.)
posted_image
You can see the relay, the video amplifier for the LCD's, the PAC OEM2 which is my line out converter
I have the spliced into the wire running into the rear channel speakers because they are full range. I ran these into the PACOEM2 and then ran the output into the 1+2 input on the Amp.
posted_image
The amp is then wired to the rear speakers, the subs and it works perfectly. The rear and the Subs are bridged.
posted_image
When i wire the front speakers, the amp just puts out a high buzzing tone.
I've tried to wire the front speakers into where the back are wired now and they work fine, but when I try the pack where I want to wire the front, I get the same high pitched buzz tone. I can't get them to work on where i want to wire them on the amp (it's actually labeled as the rear out on the amp, but I'm attempting to use it at the rear out. I can't think that this is the problem because when I try to wire the front speakers into the front and the rear into the rear, the problem is still there.)
posted_image
I have also tried adding and RCA input into the 3+4 input on the amp and the same problem happens. I have also tried switching RCA cables. I have also tried to have all the levels adjusted, the Phase 0 or 180, the sub input on/off, and the 3+4 input on/off.
What am I doing wrong???
Date Posted: March 28, 2008 at 11:51 AM
Just to clarify, the sound that's coming out isn't a background hiss or an engine noise, it's a buzz!! like the emergency broadcastings system, but constantly.
Date Posted: March 28, 2008 at 11:54 AM
posted_image
Posted By: DYohn
Date Posted: March 28, 2008 at 12:04 PM
Could be a bad amplifier, bad LOC, bad speaker... if you swap the fron input to the rear channels, does the noise move with it?
Date Posted: March 30, 2008 at 12:49 PM
There seems to be a problem only when the channel is bridged... when i don't bridge them, they're fine. I ve never run across this before.
