eq’ing the sounstage?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103775
Printed Date: May 05, 2026 at 2:47 PM
Topic: eq’ing the sounstage?
Posted By: Alpine Guy
Subject: eq’ing the sounstage?
Date Posted: April 06, 2008 at 6:26 PM
My friend has a Silverado with the Q-Logic kick panels and the sound stage is low, if you listen for where the sound is coming from you look directly at the kick panel. Is it possible to use processing to virtually raise the sound stage? It really bugs him...understandably!
Posted By: haemphyst
Date Posted: April 06, 2008 at 9:08 PM
Not likely. It's not an EQ issue... More likely it is a crossover issue or a spacing isue, or a timing issue.
EQ won't fix it, I think.
Date Posted: April 06, 2008 at 10:19 PM
I'll play with the time correction a bit and see what that does, I guess that could be all wacky which could be why whatever seat your in, the closest speaker is all you hear.
