panasonic cq vd 6503u pdf
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103844
Printed Date: May 05, 2026 at 2:47 PM
Topic: panasonic cq vd 6503u pdf
Posted By: septicdeath
Subject: panasonic cq vd 6503u pdf
Date Posted: April 08, 2008 at 10:06 PM
Any one got a .PDF of the factory install manual for the CQ-VD6503u?
If not, can someone provide at least a harness break down. I have the harness from Panasonic, but its missing the markings to tell me what wires are what. I'm figuring that they are pretty standard, and have most of it figured out. However, there is both a blue and blue with white stripe. I know one is remote amp, the other is power antenna, and I know that sometimes one is +5v and the other is +12v, I'm making the harness extender and don't have bench power to test at the moment, or I would light it up with yellow/RED / black and test it, also, there is a unlabeled orange? Illumination maybe? I hate to assume that its standard, but have to believe that it is.
Thanks in advance.
Posted By: i am an idiot
Date Posted: April 08, 2008 at 10:12 PM
Blue/White is amp remote Blue is power antenna
There is no external wire with 5 volts on it. The Orange wire IS the illumination wire. Yellow red and black are the only wires you need to power it up.
