dual 6 ohm wiring x3
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103911
Printed Date: May 16, 2026 at 5:53 PM
Topic: dual 6 ohm wiring x3
Posted By: madman666
Subject: dual 6 ohm wiring x3
Date Posted: April 11, 2008 at 10:27 PM
I have 3 dual 6 ohm subs (AudioBahn ALUM10N)
and I have an AudioBahn 16000v amp
Im trying to run all three off of the amp and since this amp is not 1 ohm stable. I have been trying to figure out the best way
to wire the subs ,and I have come with a possibility but im not sure if it is a good idea.so here goes.
I would like to know if I could wire two of the subs in series (for 12 ohm operation each)
and one of the subs in parallel (for 3 ohm operation)
and then wire the three subs together in parallel (for 2 ohm operation)
If anyone has run this amp stable at 1ohm let me know,then ill just run the all in parallel for 1 ohm
Thank you in advance for any help given.
Manuel
madman
Posted By: DYohn
Date Posted: April 11, 2008 at 10:46 PM
I'd wire for a 4-ohm load.
posted_image
