lights dim more after big 3 upgrade?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104019
Printed Date: April 09, 2026 at 9:59 PM
Topic: lights dim more after big 3 upgrade?
Posted By: lanceam24
Subject: lights dim more after big 3 upgrade?
Date Posted: April 15, 2008 at 9:07 PM
i had already done my negative batt to chas, and engine block to chas(stock location) i ran a fused 4 awg power wire from my alt to positive terminal earlier and now my lights dim a lot more for some reason. they used to dim at around 18 on my head unit with my sub on, now its more like 13-15. i noticed a better throttle response whenever i performed the mod so im sure i did it right. i might run another engine block to chass. wire. nebody familiar with this?
Posted By: spookiestylez
Date Posted: April 15, 2008 at 9:16 PM
what kind of vehicle do you have? What kind of battery? What kind of equipment are you running? details...details
RTFM
Date Posted: April 15, 2008 at 10:22 PM
1996 mazda protege (60 amp alt.), optima red top battery, 1 12" kicker cvr, 1200w sony xplod amp, rockford fosgate 4 awg wiring kit, big 3 upgrade done with stinger 4awg power wire
Posted By: mtdewcowboy
Date Posted: May 11, 2008 at 5:23 PM
The sony amp is more like 500 watts if you are lucky. Have one in my garage and it never hit like my Kicker 5 channel amp. Your alt may be going out because you are not pulling that much maybe 35 or 40 amps at full power.
Valor ITS-710W In-Dash Navigation Ready DVD Player
2 SETS KICKER KS502 5.25 AUDIO COMPONENT SPEAKERS
KICKER ZX700.5 5-CHANNEL CAR AUDIO AMPLIFIER STEREO AMP
Posted By: haemphyst
Date Posted: May 11, 2008 at 6:29 PM
All this is showing you is how INEFFECTIVE the charging system was BEFORE. Now that everything is working more efficiently, the transient overloading has become more noticeable.
Now, you need either a new battery, a high output alternator, or (preferably) both
