225 hcca, single 10’’ kenwood
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104023
Printed Date: April 09, 2026 at 8:08 PM
Topic: 225 hcca, single 10’’ kenwood
Posted By: blownpsd
Subject: 225 hcca, single 10’’ kenwood
Date Posted: April 15, 2008 at 11:48 PM
Its a 1st gen and I have the 400 bdg bridging module. I used the "summed mono" which I assume is the right port to use, not the "mixed mono".  It is ok for output, not as loud as I expected, but pretty good for a single 10" Kenwood dvc in an approx 1 cu ft sealed box.  I may try porting it and see if I like it.  It's tight like I wanted, just want more pound.  Very clean though!! Rock on old school orion.
always need more power
Posted By: i am an idiot
Date Posted: April 16, 2008 at 3:16 AM
The impedance of the voice coils are ??? How did you wire them, in series or parallel?
Posted By: blownpsd
Date Posted: April 16, 2008 at 8:31 PM
wired in parallel the impedance of the coils are 4 Ohms each
Date Posted: April 16, 2008 at 9:05 PM
At 2 ohm mono that amp will put out around 200 watts. If you are going to hook up only 1 woofer to the amp, you really need dual 2 ohm coils.
