amp gain w/different box, grounding kits?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104090
Printed Date: April 08, 2026 at 12:54 PM
Topic: amp gain w/different box, grounding kits?
Posted By: inoitall
Subject: amp gain w/different box, grounding kits?
Date Posted: April 18, 2008 at 10:12 AM
I have a few questions I need answered. To start, my friend has an amp which is currently powering 2 12" subs. Those subs are in a bandpass box (yes I know yuck). He has the gain set properly to 1/2 using a test tone cd. He has the low pass crossover set properly and has the bass boost at 0. He wants to replace the bandpass box with a ported box which Is already made. What he wants to know is... does he need to adjust the amps gain at all? I know a bandpass box doesnt have the output that a ported box does, and his amp isnt even stressing the subs. The amp isnt clipping it all, so he was just wondering if he could leave the gain where its currently at?
Ok now my question. I have 2 batteries, the main and 1 in my trunk. I have read about these grounding kits that allows you to make several grounding locations go to 1 point. For instance you can ground the battery, engine block, headers, and so on to 1 location which in turn would help overall performance. Also, I was thinking about getting 2 of those, 1 for each battery. The one in the trunk I would ground the battery to, along with my cap, and my 3 amps. That would give each amp and cap 2 grounding points. Would that at all help, or would the possibly creat a ground loop, or solve a ground loop problem (which I have with 1 of my amps)? Thank you.
Posted By: haemphyst
Date Posted: April 18, 2008 at 10:29 AM
How do you KNOW the amp isn't clipping? One of the bad things about bandpass enclosures is the fact that nearly all of the non-linearities caused by clipping and over-excursion are filtered out... You simply don't hear them, even if they are happening. That amp could be BADLY clipping, and you might never know it unless you are viewing the waveform on a 'scope. At high enough levels, yes, you CAN hear those distortions, but it has to get quite a bit higher than a vented or sealed enclosure.
Also, if output is what he is looking for, then the bandpass IS THE WAY TO GO! The bandpass is HIGHLY efficient, significantly moreso than the vented (and especially the sealed) enclosure.
As far as your grounding question: If you can bond multiple points together, you may or may not benefit. If you are already experiencing ground loops, then I suspect a ground issue at one or both of your batteries, as you do. What steps have you already taken to bond front and rear batteries with the system, including all processors and head unit?
Posted By: DYohn
Date Posted: April 18, 2008 at 10:35 AM
IMO, any time anything in the system gets changed, gains should be re-set.   This may sound like overkill is speakers are being swapped and the impedance loading is the same, but I generally don't trust what's printed on the box...
Posted By: inoitall
Thanks for the reply. What i told my friend to do was use the test tone cd which is 60 hertz I think, have the volume where he listens to it at, have the gain all the way down and the sub output on the headunits all the way up, and then slowly turn the gain up untill the bass changes "tones". The gain was at alittle above half when the bass changed from good bass to choppy, nasty sounding bass. Then I told him to turn the gain back down a tad and leave it go.
With my grounding kit question, what do you mean by processor and headunit bond?
Date Posted: April 18, 2008 at 11:16 AM
What I mean is this: "Where are the amps, batteries, and additional components all grounded?"
Posted By: inoitall
Date Posted: April 18, 2008 at 11:22 AM
Oh ok sorry. Ok each amp is grounded seperatly, yet grounded within 3 inches of eachother. They are grounded on the driver side of the trunk floor. The cap and battery are also grounded in that general location.   DYohn, are you basically saying that a ported box has more of an output than a bandpass, thus giving me the reason to adjust the gain? I can understand doing this if going from a sealed to ported because youll need the gain higher for a sealed. I will tell him that when he changes them to the ported box, to simply re-due the gains.
Posted By: aznboi3644
Date Posted: April 18, 2008 at 2:53 PM
With the suboutputs on the HU all the way up you may very well be clipping the output signal from the HU...then if the amp is clipping than its clipping an already clipped signal which is even worse
Posted By: DYohn
Date Posted: April 18, 2008 at 8:25 PM
inoitall wrote:
 DYohn, are you basically saying that a ported box has more of an output than a bandpass, thus giving me the reason to adjust the gain?.
No, I'm not saying that at all.  I'm saying that every speaker is different and if you want to be sure you have it right, you need to properly set the amplifier gain for the speakers you are using.  4-ohms is not always 4-ohms, and clipping can happen at completely different levels with different loading on the amp.  It has nothing to do with the amount of output from the speaker system.
Posted By: inoitall
Date Posted: April 18, 2008 at 9:08 PM
id like to focus on the grounding kit area if thats ok. If my friend has questions to ask, then he can become a member. I just wanted to know if it is worth getting a grounding kit and use it for my amps, cap, and trunk battery? This would give each of those 2 grounding points instead of 1. Would this help my system (basically the equipment themselves) to perform better?
Posted By: stevdart
Date Posted: April 18, 2008 at 10:13 PM
With most systems, there would be no performance enhancing whatsoever.  It might just be a matter of convenience (in some cases) to use another grounding kit with the additional amp.  For instance, if the former install has built-in or hard-to-get-at wiring components.
You just have to consider that the grounding wiring is a mirror image of the power wiring.  If power starts at 2 ga and distributes 4 ga. to each amp, then each amp grounds out a 4 ga. to the ground block, which then supplies a 2 ga. ground to chassis.  If there is no ground distro, ground each amp with either 4 ga. or 2 ga. to chassis (following the rule that the ground wire must be at least as large as the power wire).
Look at the install as it is now.  If the distro block needs to be upgraded to supply more or larger gauge wiring, replace it.  If there is no whine or hum (and therefore no ground loops) in the current system, stay with the same grounding point if possible, or within an inch or so from it on the same chassis panel.  You don't want to spread the ground points around.
Posted By: inoitall
Date Posted: April 19, 2008 at 8:08 AM
Ok. Yea all of my grounding points are very close to each other. Out of those 3 amps, only 1 amp has a ground loop problem but its only the 3rd and 4th channel. It cant be a grounding problem then. All of the amps grounding wires are the same gauge as their power wires. I just thought that just maybe by having more than 1 grounding point would help the amps alittle more. But if my amps already have good grounds along with the correct ground wire gauge, then there is no point. But I will still get a grounding kit to mount under the hood. Just 1 more question. How can I check to see what voltage is coming out of the sub output on the headunit? Do I simply use a DMM to those RCA cables or what? And if you use a DMM, can you please explane what setting to have it on and so on, because I have no clue how to use them. Very sorry. But thank you.
Posted By: inoitall
Date Posted: April 20, 2008 at 11:53 AM
How good are those voltage stabilizers that I see on ebay?
Posted By: inoitall
Date Posted: April 22, 2008 at 8:48 PM
Does anyone know anything about the voltage stabilizers?
Posted By: audiocableguy
Date Posted: April 22, 2008 at 9:16 PM
audioboy2007 asked the same question "voltage stabilizer" in which 'ground kit' was answered.
Posted By: DYohn
Date Posted: April 22, 2008 at 9:29 PM
I thought these questions sounded familiar...
