bandpass vs ported
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104139
Printed Date: March 26, 2026 at 4:08 AM
Topic: bandpass vs ported
Posted By: inoitall
Subject: bandpass vs ported
Date Posted: April 20, 2008 at 7:19 PM
I just wanted to know the pros and cons of each box. I currently have a dual bandpass box but I also have 2 single ported boxes that were made for my subs about 4 months ago. The bandpass box I have had for over 5 years. I want something that will give the killer bass at all frequecies, yet wont mess or blow the subs. Thank you in advance.
Posted By: mcben789
Date Posted: April 20, 2008 at 8:39 PM
search it up...click whoo!
Sasquatch...
We know your legend's real...
Posted By: inoitall
Date Posted: April 21, 2008 at 2:19 PM
Ok I looked at that link but it doesnt really help me out much. Basically a ported box is for SPL, a sealed box is for sound quality, and a bandpass box is for alittle spl and SQ. I guess I will just stick to my bandpass. I want some spl and sound quality, but am just afraid that If I used the ported boxes, that I would lose the SQ.
Posted By: haemphyst
Date Posted: April 21, 2008 at 2:55 PM
In order of output capabilities (SAME woofer, SAME power) would be sealed (least output), vented and bandpass. Coincidentally, the order is EXACTLY the opposite for QUALITY of output, with sealed being recognized as the best for sound quality.
What is your desired goal? Output with respectable extension will nearly ALWAYS be a properly tuned vented enclosure, being as it offers the best in trade-offs.
Bandpass enclosures are horriffic enclosures from a sound quality standpoint. They "pass a band" of frequencies, (usually less than one octave flat, but if mistuned on purpose, you can get several octaves with HUGE response peaks on both ends) but do so very effectively, thus the output capbilites of such. Their group delay, transient response and extension ALL SUCK, relative to a quality vented enclosure, and aren't even in the same FIELD as a sealed enclosure. Generally, they are "one note wonders", offering little to NOTHING in the way of extension, unless you are using a HUGE!!!!!!!! enclosure. Even in this case, (speaking for the extension part) you won't ever get anything in the way of higher frequencies in the arena of "bass". One octave, remember?
Pros and cons? (and these are specified agains each other, sealed enclosure is NOT part of these)
Vented pros: Transient response, output, wider frequency response, easier to build and tune properly, more woofers to choose from, CAN be quite audiophile.
Vented cons: less output
Bandpass pros: more output
Bandpass cons: TERRIBLE frequency response, terrible transient response, TERRIBLY difficult to build correctly, destructive distortions (including amplifier clipping, and overexcursion) cannot be heard easily, fewer woofers are available than CAN be used in a bandpass effectively, have no place in a SQ system.
Posted By: audiocableguy
Date Posted: April 21, 2008 at 5:09 PM
What subs are you using?
Posted By: DYohn
Date Posted: April 21, 2008 at 5:41 PM
In general bandpass is the lowest SQ of any typical alignment so if you are seeking better SQ, dump the bandpass idea.  A well-designed bass reflex (ported) alignment will have FAR better SQ than a bandpass.  I suggest if you want to understand the differences and how each type works, start here: https://www.diysubwoofers.org/
Date Posted: April 21, 2008 at 11:05 PM
"improperly tuned box". We have been over this ground before. Read down and find the relative info about ported and bandpass boxes.
