amp enters protection after volume 11
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104779
Printed Date: April 08, 2026 at 8:04 PM
Topic: amp enters protection after volume 11
Posted By: charney
Subject: amp enters protection after volume 11
Date Posted: May 16, 2008 at 12:58 PM
I am having issues with my amp entering protection mode after my stereo reaches volume 11. I have a pioneer TS-WX100BP setup and I am attempting to power it with a Sony Xplod XM-554ZR amplifier. I have had this sub powered by a Thump amp previously, but it stopped working, and i wanted a new one. The sony amp is brand new, and i have had the sub and box for a while now. After connecting everything the sub works until i hit volume 11. As soon as i go from10 to 11 the amp enters protection mode.( I usually listen to music around 25 to 30 volume) I would appreciate the help.
Posted By: joch1314
Date Posted: May 16, 2008 at 1:14 PM
What impedance is your sub, and is your amp a 2 channel, 4 channel or a mono amp? it may have to do with the fact that the subs impedance it to low, and the amp can't handle the load that the sub is demanding from it! ------------- ...half of the truth can be worse than a lie. <----Roger Russell said that..
Posted By: charney
Date Posted: May 16, 2008 at 1:18 PM
My amp is a 4 channel amp, and my sub is a 4 ohm SVC
Posted By: tubbs04
Date Posted: May 16, 2008 at 1:51 PM
how do you have the sub wired into the amp?
------------- ...don't crush the weasel...
Posted By: DYohn
Date Posted: May 16, 2008 at 2:14 PM
... and how did you set your gain? ------------- Support the12volt.com
Posted By: haemphyst
Date Posted: May 16, 2008 at 2:16 PM
The BEST you can hope for would be bridging two of the amp channels. You CANNOT use all four channels with a single voice coil woofer.
The 554 amp (I am gonna guess) is 55 watts X 4, at 4 ohms correct? Into 2 ohms, maybe 75 to 100 watts? In the case of a single 4 ohm bridged load, the amp will make around 150 to 200 watts per bridged pair. (It IS a Sony, so take those numbers with a BIG grain of salt...) The other channels must remain either unused, or connected to another woofer (or woofer voice coil, if you had a dual 4 ohm voice coil woofer) or speaker set.
------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
Posted By: charney
Date Posted: May 16, 2008 at 3:39 PM
I bridged the two rear channels like the manual said to. Thats also how i had it with my old amp. To set the gain i had the gain as low as it would go and put my volume around medium of what i would use it and then turned the gain up....it also shut off after i turned the gain up past 3 quarters.
Posted By: i am an idiot
Date Posted: May 16, 2008 at 3:53 PM
Do you have a Pioneer radio? Have you tried bridging the 2 front channels of the amp instead of the rear channels?
Posted By: chillin420
Date Posted: May 16, 2008 at 3:56 PM
your gain should not be that high. should be around 0 to 30 % at max that is about as far as i will take any gain. if it still isnt loud enough then you need a bigger amp.
------------- you can do it....
advanced MECP, lol does it really matter....
patience is a virtue
Posted By: sedate
Date Posted: May 16, 2008 at 4:44 PM
charney wrote:
| I am having issues with my amp entering protection mode after my stereo reaches volume 11. |
I had the same problem with my new Alpine HU right - for weeks I couldn't figure it out. Checked the gains, voltage, everything. I called Alpine, JL Audio, probably posted here. . . . Turns out I was so drunk when I wired the deck I hooked the left-front-negative speaker lead to the remote turn on.  ------------- "I'm finished!" - Daniel Plainview
Posted By: tubbs04
Date Posted: May 16, 2008 at 5:10 PM
I love it!!! That makes me feel better knowing I'm not the only one that does these types of things after consuming lots of alcohol.... My problem is getting tanked, then think its a good idea to start a project, get half way through it, then say "F* it... lets go drink some more," then have to come fix the mess the next day with a hangover.... ------------- ...don't crush the weasel...
Posted By: charney
Date Posted: May 16, 2008 at 5:51 PM
I have a kenwood head unit, the remote and everything are wired correctly, because i have had my dash taken apart about 4 times checking on that stuff.
Posted By: KarTuneMan
Date Posted: May 17, 2008 at 9:47 PM
haemphyst wrote:
The 554 amp (I am gonna guess) is 55 watts X 4, at 4 ohms correct? Into 2 ohms, maybe 75 to 100 watts? In the case of a single 4 ohm bridged load, the amp will make around 150 to 200 watts per bridged pair. (It IS a Sony, so take those numbers with a BIG grain of salt...) .
Curses.... those damn Sony watts. (who was the author of that post giving "in depth" description of the Sony watts?) That was one of the funniest things I have ever read! -------------
Posted By: DYohn
Date Posted: May 17, 2008 at 10:22 PM
Why thank you for remembering... https://www.the12volt.com/installbay/forum_posts.asp?tid=52982&KW=sony+watts ------------- Support the12volt.com
Posted By: Velocity Motors
Date Posted: May 18, 2008 at 8:33 AM
Someone had their thinking cap on that day...lol ! As far as the amp going into protection mode, have you check for an absolute ground on the amplifier ?
------------- Jeff
Posted By: charney
Date Posted: May 18, 2008 at 4:51 PM
how do you check for an absolute ground?
Posted By: 95gt
Date Posted: May 18, 2008 at 8:48 PM
Get a 5th of Absolute Vodka, chug it and in 30 minutes or so you'll be absolutely grounded
Date Posted: May 18, 2008 at 9:04 PM
You really need to try running the front channels of the amp. There may be a problem with one of the rear channels of the amp. If it still has a problem you need to get a Volt meter, and right before the amp is at the point of cutting out, check voltage at the power and ground terminals of the amp.
Date Posted: May 19, 2008 at 10:53 AM
forbidden wrote:
"take one probe direct to the neg battery terminal and the other probe to the potential grounding location. This will show the resistance from the battery instead of between two points. Never touch the probes as it throws the reading off. If the probes do not reach, use an extension wire to lengthen the reach. A reading of under .05 ohm is what I usually shoot for."
------------- Jeff
