intermintent xtant amp problem repair?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104893
Printed Date: April 08, 2026 at 10:59 AM
Topic: intermintent xtant amp problem repair?
Posted By: vw-337
Subject: intermintent xtant amp problem repair?
Date Posted: May 21, 2008 at 10:38 AM
I've got a Xtant 6.1 powering one JL 10.
The amp has developed an intermintent problem.  The sub will pop, cut out, or thump if you jostle the amp around.  It typically happens when you smack the amp right above the section with the gain controls and rca inputs.
I opened the amp up to check for anything obvious (loose components, broken solder joints, etc) but couldn't find anything.
I resoldered the joints for all the pots (gain, xover, bass boost, and subsonic filter), as well as the rca posts, but that didn't help at all.
What should I try next?  The amp works fine when it's working, and seems to be directly related to a loose or poor-contact component.
On a side note, I did find a really cool feature inside the amp on the board near the preamp stage.  4 surface mounted LED's that are like a vu meter.  They show when you start clipping the input.  Not sure why they're buried inside.  It's a useful feature that could have been incorperated into the casing.  You'll never see them without pulling the cover and voiding your warranty...
Posted By: vw-337
Date Posted: May 21, 2008 at 10:47 AM
Just remembered -
Some times when you smack the amp, the sub fully extends as if it's receiving pure DC.  Smack it again and it goes back to normal.
Posted By: DYohn
Date Posted: May 21, 2008 at 1:50 PM
Sounds like a defective amp.  Is it under warranty?
Posted By: vw-337
Date Posted: May 21, 2008 at 3:16 PM
It's not under warranty.
I know it's broke, I'm looking for ideas on what to check so I can repair it.
Posted By: boogeyman
Date Posted: May 21, 2008 at 6:58 PM
  I ran into that problem once, when you smack the amp, and it turned out to be a cracked circuit board , turned out the customer was into a car wreck.  Dont know if thats the case with you but just sharing my similiar experience.
Posted By: spookiestylez
Date Posted: May 21, 2008 at 11:32 PM
look into replacing your amp or having it professionally serviced. That way you don't end up needed to replace more equipment (like subs) when/if the amp fully fails. Beats hiring a midget to smack on your amp every time you need some bass, lol
RTFM
