reverse mounting subwoofer wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104956
Printed Date: April 07, 2026 at 7:13 AM
Topic: reverse mounting subwoofer wiring
Posted By: knockn4life
Subject: reverse mounting subwoofer wiring
Date Posted: May 23, 2008 at 10:14 PM
i have a 15" rockford hx2 that i just reverse mounted on a shallower box that it had and i lost sum bass. i connected the + and - reverse but im not sure if i have to switch the 0* or 180* phase on my headunit or amp. oh and i have the sub wired at 1 ohm and i dont know if i need to re arrange the wiring on this too or just leave it how it is. please help!!!!
2001 dakota r/t 1 15"RF HX2
1 1000BD power amp 1 1 farad cap 4 channel amp
Posted By: DYohn
Date Posted: May 23, 2008 at 10:17 PM
If you only have one speaker there is no need to wire it in reverse polarity.  What do you mean you "lost sum bass"?
Date Posted: May 23, 2008 at 10:29 PM
its doesnt hit as hard as it did in the sealed box that i had it in. it gets distorted when i turn it up at the volume that i used to beable to listen to it at.
Posted By: stevdart
Date Posted: May 24, 2008 at 6:22 AM
You downsized the enclosure airspace?  So you're comparing output as it is now to what it was in a larger box.
