’04 honda accord amp fitting
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105021
Printed Date: May 21, 2026 at 4:33 PM
Topic: ’04 honda accord amp fitting
Posted By: konaras
Subject: ’04 honda accord amp fitting
Date Posted: May 26, 2008 at 4:01 PM
Hi there.
I've got Honda Accord '04. It has premium sound system, 6cd changer, touch screen display and sat nav. But the sound is not powerfull enough, so I'm fitting amp in it. Therefore got some problems:
1.Where should I connect the amplifier remote wire?
2. What about line out. Can I take it from rear speakers? Won't it make any damage to head unit if I do so? ( I'm sure there won't be any RCA outputs on the back side of head unit)
Thaks in advance.
Posted By: csnut18
Date Posted: June 03, 2008 at 4:51 PM
Yes, You can take it from the rear Speakers. A line output converter is made for what it does and wont damage anything. You can connect the remote wire to either the cig lighter wire(cause it turns on and off with ignition in your car) or you can check the wiring diagram and see if your the accord has a factory turn on wire.
