98 deville headunit
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105674
Printed Date: March 26, 2026 at 11:39 AM
Topic: 98 deville headunit
Posted By: matt_attack
Subject: 98 deville headunit
Date Posted: June 24, 2008 at 11:38 PM
I have a 98 Cadillac Deville and im having trouble getting infromation on how to install an aftermarket HU and what brackets I'll need. I usually get them from crutchfield but they dont have specs on this year. The HU im going to be installing is the Kenwood Excelon KVT-717. Also, if anybody could give me some input or suggestions on some comp sets. Ive narrowed it down to either 2 sets of Infinity Kappa 50.9cs for the front doors and rear deck or JL Audio VR525-CSI for the front door and JL Audio VR600-CSI for the rear deck. The amp I'd be using for the comps would be the Rockford Fosgate Power T600-4 or T400-2. Any help and suggestions would be greatly appreciated. Thanks in advance.
98 Cadillac Deville
Rollin stock 4 now
Posted By: brandonz
Date Posted: June 25, 2008 at 12:57 PM
All you have to do to get the factory radio out is the following:
1. Carefully pull out on radio trim bezel.
2. Push tabs in on sides of factory stereo, slide radio out, unplug, and remove.
The Scosche mounting kit would be GM1584B and the Metra mounting kit would be 99-2004.
I have a Kenwood deck, and infinity speakers. I can't speak on behalf of JL as far as speakers go. I can vouch for the Infinity's though. I also have a Rockford Fosgate amplifer in the mail as we speak. I'd imagine the JL's would be the more popular choice, however, if it were me I rather be a little different, and go with the lesser popular brand.
Posted By: djmostry
Date Posted: June 25, 2008 at 3:18 PM
on this car its better if you run the power and accesory from the sterring column because the factory harness loses power after 30 minutes and you will lose the memory on the car
pablo
Date Posted: August 16, 2008 at 9:48 PM
If i get the Metra GMRC-03 GM Data Interface Harness hooked up will that prevent the memory loss? i saw a couple other threads where people were having that problem on caddies. Also this model has steering wheel controls if i hook up the Metra ASWI-JACK adapter would this make them still operable? Thanks for the help.
98 Cadillac Deville
Rollin stock 4 now
