Feedback on some amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10573
Printed Date: May 03, 2026 at 3:49 PM
Topic: Feedback on some amp
Posted By: pervitizm
Subject: Feedback on some amp
Date Posted: March 07, 2003 at 11:59 PM
I'm shopping around for a new amp to hit my L5 off properly. I have the DVC 4hom model 15's and I want to be able to run them Series/Parallel to get a 4ohm load. I'm looking for an amp that will give me around 1000 to 1500 rms at that load. Now I have a Lighting audio 1000.1D that's capable of giving me the 1000 rms but only ath 1 ohm. I wanna try and avoid running at the low of a load. So I've been searching and searching the web looking for the right amp that will give me the power that I need in 4ohm, so let me know what you guy's think about these amp. Also, I'm trying not to go over my budget that I have for the amp, which is $800.
Here are the amps(names and spec)www.etronics.com: 1)SoundStream PIC1.1400D Picasso Series 1 Channel Mono Amplifier price: $419.99 TST™ (Twin Stack Technology) 2 amplifiers to drive one voice coil effectively doubling the power. Fully regulated, MOSFET power supply PWM circuitry High quality FR-4 circuit board Satellite Power Gain (remote gain control) Continuously variable 24dB low-pass crossover (50Hz to 150Hz) Continuously variable 24dB subsonic filter (50Hz to 150Hz) Variable 0 – 18dB subwoofer equalizer @ 40Hz Continuously variable phase alignment (0°- 180°) Tri-guard amplifier protection Intelligent Distress indicator (IDI) Platinum RCA input and output Platinum 1/0 gauge power inputs 1-ohm stable 5Hz – 250Hz frequency response >80dB S/N ratio 0.30% THD RMS @ 4 ohm: 350 Watts x 1 RMS @ 2 ohm: 700 Watts x 1 RMS @ 1 ohm: 1400 Watts x 1
2)SoundStream TR1760/D Tarantula Series 1 Channel Digital Class Amplifier price: $599.99 RUBI™ (Rapid-Use Branched Impulse) Proprietary power supply topology STACT™ (STabilized Apex Current Topology) Reduces power supply stress by 50% Trident™ Amplifier protection topology Tone Sweep Calibration Optimizes the power supply to the connected speaker load. Hawkins Bass Control™ Proprietary bass equalization topology Continuously variable 12dB low-pass crossover (30Hz to 4kHz) Three Stage Input Level Indicators Output Clip Indicators IDI™ (Intelligent Distress Indicator) gives visual amplifier protection status Large Mouth Bass remote gain control Continuously variable phase alignment (0° - 180°) Vortex induction fan for thermal management Differentially Balanced RCA Input Fully Balanced 6-pin DIN Input RCA Line Output Gold plated 1/0 gauge power inputs Harmonic Bass Alignment™ Produces tighter, more accurate bass reproduction. Discrete Balanced Class A Drive Boards maximizes linearity on low impedance loads Drive Delay 2™ Eliminates turn on and turn off pops & noises Chassisink™ Transistors are located between circuit board and heatsink for optimal heat dissipation Power Grid™ Design optimizes current delivery to and from the power supply 20Hz – 500 Hz Frequency response >115dB S/N ratio >500 Damping 300mV – 5.0V Input sensitivity 0.02% THD All Chrome Plated RMS @ 4 ohm: 440 Watts x 1 RMS @ 2 ohm: 880 Watts x 1 RMS @ 4 ohm (mono): 1760 Watts x 1
3)Eclipse DA-7122 2000 Watts Power Amplifier price: $599.99 Maximum power output of 2000W into a 2 Ohms load Class D optimized for low frequency reproduction Twin ICE power amplification Peak output current in excess of 50A Immense 120dBA dynamic range for effortless reproduction of the lowest frequencies Built-in protection against over and under-voltage conditions Additional protection for amplifier and speakers as well as soft clipping and soft start-up functions Balanced inputs and outputs Integrates seamlessly with total system Quality construction throughout
These are the three amps that I found tonight online and thought I would share them with you guys to get some opinions on these amps since I've never used their products before. Also I'm really intrested in the Memphis MOJO amp. If anyone know where I can find this amp online or someone selling them for less than the $1300 I've been quoted on then please let me kow
------------- live & die 4 tha luv of BASS!!!!
Date Posted: March 08, 2003 at 6:51 PM
Anyone out there gonna help answer my question?
