1994 ford ranger door panel
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105955
Printed Date: April 10, 2026 at 2:39 PM
Topic: 1994 ford ranger door panel
Posted By: pv13
Subject: 1994 ford ranger door panel
Date Posted: July 06, 2008 at 11:07 PM
I am having trouble removing the door panel on my uncle's 1994 Ford Ranger. There are no power windows or locks, and everything is manual. I removed the 3 screws that are on the door panel, but I can't remove the window handle. I have a window crank removal tool, but for some reason it is not grabbing on the C clip.
And once I find out how to remove the handle, I also need to know if the door panel has clips or hooks because I don't want to bend the panel if it has hooks.
I would appreciate any help I can get.
Posted By: dtpaudio
Date Posted: July 10, 2008 at 6:00 AM
I had a 93' Explorer. It's easy. Ditch the tool and grab a small rag or something. Twist it up like you're about to snap spmebody with it and then just shimmy it in. It should grab the clip a lot easier than the tool.
Be loud,be obnoxious,man up, and bounce with a legend.
Posted By: haemphyst
Date Posted: July 10, 2008 at 9:05 AM
Ummm.... I think on some of the Rangers there is a T-10 Torx in the middle of the big end of the handle.
Otherwise:
Posted By: megaman
Date Posted: July 10, 2008 at 12:23 PM
Don't twist, yank, grab, or torque....
The large part of the handle that attaches to the door has a t-10 torx bit keeping the window crank on.
Posted By: pv13
Date Posted: July 12, 2008 at 1:27 PM
There was a torx bit in the window crank.
Thanks guys.
