blowing fuses
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105994
Printed Date: April 09, 2026 at 6:25 PM
Topic: blowing fuses
Posted By: lukee b
Subject: blowing fuses
Date Posted: July 08, 2008 at 5:43 PM
i have a 2000w hifonics brutus hooked up to 3 12' cvrs. i am almost certain that it is hooked up properly wired in a series at 2ohm (atleast it should be. the meter says 1.8) i have 1/0 gauge wire from battery to a distro with clear glass type fuses. the largest fuse i can find is a 100A and i blow it in about 2 min with amp all the way up. slightly frustrating. suggestions??
------------- pioneer6600
3 12' cvr's
hifonics brutus 2000W
Posted By: DYohn
Date Posted: July 08, 2008 at 7:25 PM
1, with 0 guage power cable you can fuse as high as 350 amps. You need a larger fuse. Go see your local car audio shop. 2, what is the expected current draw of your amplifier? I suspect if it is really a "2000w" amp, it will pull much more than 100 amps, so blowing that fuse falls into the "duh" category. 3, what do you mean by "all the way up"? If you mean your gain control, then you need to set it properly. It is not a volume control. Try the forum search function. 4, please explain how you can wire three speakers in series and achieve a 2-ohm load. What is the make/model number of your speakers? ------------- Support the12volt.com
Posted By: lukee b
Date Posted: July 08, 2008 at 8:05 PM
my problem with the fuse is that the style im using only comes up to 100amp. i am now searching for a new distribution block.. any suggestions? ..... the wiring diagram says that the series should be 1.34 but meter says 1.7-1.8. by all the way up i mean gain. does this not control the power from amp to speaker.. i dont know the draw of the amp.. it is a bxi2008D HIFONICS..someone at a local shop told me the amp is not 1ohm stable. how can that be when it is advertised so? ------------- pioneer6600
3 12' cvr's
Posted By: DYohn
Date Posted: July 08, 2008 at 9:24 PM
That is a 650 watt amp and it is advertised as 1-ohm stable (and supposedly capable of 2000 watts into 1-ohm) but I can only imagine the horrible distortion it puts out into a 1-ohm load, and I would not be surprised if it really cannot sustain 1-ohm. In any case, you need to do a few things.: First, you need to get the proper fuse for your power system. You are using the wrong style fuse. Go to a car stereo shop (not Best Buy) and ask for a wafer fuse. Tell them the wire size you are using. And no you don't necessarily need a distribution block... by the way, I am talking about the main system fuse that should be at your battery. Is this what you are talking about? Next, no, your gain is not a volume control and it should NEVER (did I say NEVER?) be all the way up. No way in the world! You need to set it to match the output level from your head unit. CLICK HERE. And lastly, you say you have 3 Kicker Comp VR subwoofers, but what model? Are they dual 2-ohm or dual 4-ohm? ------------- Support the12volt.com
Posted By: whiterob
Date Posted: July 09, 2008 at 2:20 AM
What meter says 1.7-1.8? 1.34 is the impedance that you wire your subs at. You cannot measure impedance with a simple ohm meter. What you would be measuring is the DC resistance (usually the Re spec of the sub). This is not the same. Also, even if you did measure the impedance you would not expect it to be exactly at 1.34 ohms.
What model subs do you have? How would you wire in series and get a 1.34 ohm load?
As DYohn said, you should NOT have this all the way up. The reason is a little complicated so I'm not going to try to explain but I will say that it is NOT a volume control, again as DYohn said. Basically you are trying to match the signal from the source (Head unit or whatever your RCAs are connected to) to the input on the amp.
Setting the gain too high will cause your amp to clip. This can seriously damage your equipment. Not to mention you will hear a lot of distortion.
Posted By: lukee b
Date Posted: July 10, 2008 at 9:07 PM
they are dual 4 ohm..... yes i am using a simple ohm meter(but that is interesting) I got the fuse thing under control...How can the amp be a 650w amp and where did you get this info?. i can have the level on the amp all the way up with no clipping or distortion(that i can hear)
3 12' cvr's
Posted By: DYohn
Date Posted: July 10, 2008 at 9:23 PM
Two DVC 4-ohm speakers can be wired for 4-ohms or for 1-ohm impedance, and if they are all in series like you think then you have 16-ohms... and like was mentioned above, you cannot read impedance with an ohm-meter. Use the Subwoofer Wiring Options link to the left to see what your wiring configuration should look like. 650 watts @ 4-ohms is what Hifonics rates your amplifier model number at. Any other loading producing higher wattage outputs voids all the other ratings listed for this kind of amplifier. It is a 650 watt amp that is capable of sustaining higher loads (lower impedance) but not at any specified distortion, frequency response, etc. rating. If you do not set your gain properly you will destroy your speakers as the amplifier will most certainly be clipping, whether you think you can hear it or not, and this will eventually fry the voice coils. Perhaps if you really do have all four VCs in series for a 16-ohm load... in which case your amplifier is producing approximately 162 watts at max output so perhaps you COULD crank the gain without hearing the clip... Fix your wiring. How did you "get the fuse thing under control"?? ------------- Support the12volt.com
Posted By: lukee b
Date Posted: July 10, 2008 at 9:56 PM
the voice coils are in a series and speakers parrallel. there are three of them not two and they are wired like the first diagram option in (3 4ohm speaker)....i am putting a 150amp breaker where the distro is...i have 3 amps. the other two are for highs but are reasonably small. i plan to put all of them on the breaker in the rear (also have 150a breaker under hood)...i have turned the level on the amp down and am not blowing the fuse. do you think all three amps will trip the breaker.( A 200w boss and a 300w jensen) ------------- pioneer6600
3 12' cvr's
Posted By: lukee b
Date Posted: July 10, 2008 at 10:06 PM
i have a fourth and considering building box. or maybe scrapping for 15s. would i have better wiring options with 4. and would the amp work better ------------- pioneer6600
3 12' cvr's
