2006 dodge ram alternator noise big time
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106078
Printed Date: April 09, 2026 at 12:36 PM
Topic: 2006 dodge ram alternator noise big time
Posted By: metz35
Subject: 2006 dodge ram alternator noise big time
Date Posted: July 12, 2008 at 6:45 PM
just did a 2006 dodge ram. did stealth box, pioneer flip out, alpines in the 4 doors, with a new alpine pdx5 five channel..... got horrid alernator whine... so far i have tried, new amp grounds, ground loop isolators, moving the rcas, moving the power wire, changing remote wire, moving the amp, any suggestions would be wonderous as it is very lound, quite possiblely the worst i have ever heard...who ever helps me figure this out case of beer on me :)
Posted By: i am an idiot
Date Posted: July 12, 2008 at 6:48 PM
Posted By: metz35
Date Posted: July 12, 2008 at 6:52 PM
would also then recommend grounding the whole radio to metal instead of the wire in the factory harness :) beers are on me!!!
Posted By: metz35
Date Posted: July 12, 2008 at 10:11 PM
anyone?
Date Posted: July 12, 2008 at 10:14 PM
Should I change my screenname to " I am Invisible "
Posted By: gus1
Date Posted: July 13, 2008 at 12:52 AM
Ground the shield on RCA's at the deck. Ground deck to same point as amp.
Pioneer is notorious for having poor ground reference on the RCA....
Posted By: metz35
Date Posted: July 13, 2008 at 7:03 AM
rodger that, grounding radio not in the factory harness but same point as the amp, and do what iam an idiot said and then ground the shields of the rcas, to the chasis of the radio...will report back tonight
Posted By: metz35
Date Posted: July 13, 2008 at 4:32 PM
Thanks for suggestion idiot the grounding worked beautifully got rid of 80% of it. Now very barrable. Any other idea to completely eliminate noise would be great. I'll get u your crown :)
Posted By: gus1
Date Posted: July 13, 2008 at 4:42 PM
Where'd you get your switched power for the deck? An interface, or the lighter?
Try unplugging the radio antenna (the only other ground not at the same point as the deck ground)
Posted By: metz35
Date Posted: July 13, 2008 at 4:53 PM
Ok unplugged antenna still noise. Switched ignition for head unit comes from a module xsvi-6502 switched acc interface by axxess
Posted By: gus1
Date Posted: July 13, 2008 at 5:18 PM
- Try another source. A media player of some sort. At the deck end of the RCA and right at the amp. Noise still there?
- Ground deck to amp ground. Also the chassis of the deck that you now have the RCAs grounded to.
It may very well be a bad deck too. It happens. Try another one.
Date Posted: July 13, 2008 at 6:24 PM
Turn the gains all the way down on all of your amps.  Does that get rid of the noise?
Posted By: metz35
Date Posted: July 15, 2008 at 7:20 PM
gains down new grounds and tried iPod. Think I still have some ignition noise?
Posted By: gus1
Date Posted: July 15, 2008 at 9:03 PM
Even on the iPod, straight into the amp? No RCA's connected, just straight into the amp. And you have noise?
