enclosure for blauplunkt sw 130.1
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106252
Printed Date: March 27, 2026 at 12:21 PM
Topic: enclosure for blauplunkt sw 130.1
Posted By: j3m573r
Subject: enclosure for blauplunkt sw 130.1
Date Posted: July 20, 2008 at 5:38 AM
Hello the12volt.com
I have a Blaupunkt Sw 130.1 Subwoofer and wish to build an enclosure for it. I brought the subwoofer on the cheap from an uncle's freind's daughter's etc, but I don't particularly want to just go out and but a pre-fab enclosure as I want to build one that will be right for this particular subwoofer.
I am ok in the woodworking area but what I am not all to familar with is converting the subwoofers Thile Small parameters and other misc infomation into the relitive internal volume needed for the enclosure. I am more after SPL than SQ but I'll take it as it comes.
If someone in this wealth of knowledge was able to tell me what volume enclosure would best suit my subwoofer this would be much apperciated
I also know that the volume of the subwoofer and the volume of any braces used in the box need to be taken into consideation.
Blaupunkt SW130.1 Subwoofer
Maximum Wattage 400w
Nominal Wattage 200w
4Ohm SVC
Frequancy 25Hz
QTS 0.56
Sensitvity 94dB
thankyou for all time and effort put in to any infomative or "smart" replys
Posted By: DYohn
Date Posted: July 20, 2008 at 11:12 AM
Do you know the Vas of that woofer?
Posted By: j3m573r
Date Posted: July 20, 2008 at 11:27 PM
No sorry I don't know the Vas of the woofer, I only have the infomation I have given.
I have emailed Blauplunkt plenty of times as to get some infomation on enclosure size and/or any greater detail on the woofer specifications but to no avail.
Posted By: j3m573r
Date Posted: July 24, 2008 at 9:39 PM
Bump
Hello again just thought I'd bump the topic back up as I am still looking for an answer.
If someone could give me even a rough estimate it would be better than the idea I have now which is none
Posted By: DYohn
Date Posted: July 24, 2008 at 9:45 PM
Qts of 0.56 generally means the woofer requires a large sealed enclosure or is best suited to infinite baffle or dipole installation.  Without knowing the Vas (at least) there is no way to predict an accurate enclosure size.  Try putting it into about 2.5 cuft sealed and see how it does.
Posted By: j3m573r
Date Posted: July 24, 2008 at 10:00 PM
Thanks for the reply
By the sounds of that the Vas is a relatively important piece of information.
