midbass drivers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106542
Printed Date: March 31, 2026 at 5:24 AM
Topic: midbass drivers
Posted By: krazykustoms
Subject: midbass drivers
Date Posted: August 03, 2008 at 3:36 AM
The speakers in my Dodge Dakota are blown and I was wanting to replace them with midbass drivers. I found two different pairs that I like but am wondering about the frequency response of them. One set has a response of 30 Hz-5 KHz, and the other is 30 Hz-500 Hz. Should I just get both pair and put the ones with 30-5000 in the front and the others in the back? Or what??? Any help I can get will be greatly appreciated.
Posted By: stevdart
Date Posted: August 03, 2008 at 6:59 AM
A response to around 5 kHz seems appropriate for a midbass, but to only 500 sounds like a subwoofer. The midbass response has to go well into the frequency range of the next driver to take over: a good response at 5000 Hz will allow for the transition to the tweeter. A driver reponse that falters at above 500 Hz, however, is suitable only as a sub and has to be crossed over to a bass driver in the normal transition region of 80 to 100 Hz. That being said, whatever driver you choose to replace the blown woofers with is not likely to work exactly right with the original crossover network. Have you given any thought to replacing the front components entirely? ------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Posted By: DYohn
Date Posted: August 03, 2008 at 10:22 AM
Yes... what speakers are "blown" and what are the brands/models of the woofers you are considering? And as stevdart mentions, how are you planning to use the new woofers? ------------- Support the12volt.com
Date Posted: August 04, 2008 at 7:22 PM
The speakers I'm replacing are factory Infinities. The fronts are component and the rear are just woofers. The brands of midbass drivers I'm debating are Audiobahn (50hz-500hz) and Kicker (50hz-500hz). As far as replacing with another component set, my tweeteres are still good and to get a good set of components is more expensive than it is buying just the woofers.
Date Posted: August 04, 2008 at 7:23 PM
sorry, the audiobahn's freq resp is 50hz-5000hz.
Posted By: DYohn
Date Posted: August 04, 2008 at 7:56 PM
So you are trying to replace a factory woofer in an Infinity setup? I can't recommend doing that unless you really don't care what it sounds like. Also, between anything with the Audiobahn name on it and anything with the Kicker name on it, Kicker is the only choice. ------------- Support the12volt.com
Posted By: jmelton86
Date Posted: August 04, 2008 at 8:13 PM
Honestly, factory replacements would be best. The fronts, at most, are about $100 each for an 05-07 w/ 'premium sound'. Same for the rears. The fronts, at most, are about $100 each for a 97-04 w/ 'Infinity brand'. $80, at most, for the rears. This is coming straight from Mitchell. ------------- 2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
Date Posted: August 05, 2008 at 5:45 PM
What would be your advice on upgrading the factory Infinity system.
Date Posted: August 05, 2008 at 7:58 PM
All speakers, including tweeters?
Big3 in 1/0G
1/0G to GTO14001
Date Posted: August 06, 2008 at 4:38 AM
Date Posted: August 06, 2008 at 4:56 AM
That was a question. Did you want to know what we'd do in your case?
Big3 in 1/0G
1/0G to GTO14001
Date Posted: August 06, 2008 at 4:48 PM
Oh sorry about that, I must have misread it. But yes I would like to know what you would do.
Date Posted: August 06, 2008 at 7:44 PM
Well, consider how much you're willing to pay. You said all 4 woofers are blown (rattling)? So you'd need to replace them all? If so, that'll cost about $200 for 4 factory replacements. I recommend keeping the factory speakers if you plan on keeping the factory radio. Call your local Chrysler dealer for info on exact pricing and availability. ------------- 2013 Kia Rio -90a alternator
Big3 in 1/0G
1/0G to GTO14001
