high pass filter on speaker.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106817
Printed Date: March 28, 2026 at 2:50 AM
Topic: high pass filter on speaker.
Posted By: tedmond
Subject: high pass filter on speaker.
Date Posted: August 16, 2008 at 12:04 AM
hey 12v. well i got a accord with a decent panasonic deck. I got an orion sub with fosgate amp. there is also a blaupunkt 4ch amp. Im using stock speakers for now but plan to upgrade. The crappy thing is my deck doesnt have a HPF built in. I turned the bass to -12 (max) but there are still low ranges hittin my speaker, I was planning to use 500uf cap in series to block it out. But what frequency should i cut it out at so it sounds good ?
should i hpf it at 80hz or 120hz. btw the speakers are 4ohms.
thanks for any input.
Posted By: hurleyloser
Date Posted: August 16, 2008 at 1:28 AM
if they're factory speakers, no premium sound, cut off at between 100-125 that should keep them playing mid without going too deep into mid bass
MECP Master Certified Technician
ASE A6 Certified Technician
Posted By: tedmond
Date Posted: August 17, 2008 at 1:38 PM
thanks for th einput.
