no sound and smoking amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107081
Printed Date: March 26, 2026 at 7:31 AM
Topic: no sound and smoking amp
Posted By: clementi
Subject: no sound and smoking amp
Date Posted: August 27, 2008 at 7:43 PM
Alright, this is my first subwoofer install.
Here's the equipment:
1999 Toyota Avalon
Kenwood eXcelon KDC-X592 Headunit
2 12" alpine type R subs (wired at 1ohm I think- I followed a diagram on this site but when I put a volt meter on it it would fluctuate and not give me a real reading)
Hifonics TXi 1008D amp (1 ohm stable)
So here's what I did- I connected all the necessary wires I got in an amp kit. The power light on the amp was not on, but I figured I needed to turn it on via the headunit. I couldn't find the setting o turn it on, but turned the headunit's amp off and faintly heard bass from my trunk (car door speakers were not working of course). I had the bass knob that comes with amp maxed and turned the volume up pretty high, but the subs really weren't too loud. Then it cut off and I turned it off and went to look in the trunk and there was a bit of smoke coming from the amp. I disconnected the +12v wire and here I am on this site.
All the settings on the amp looked like the ones here https://sonicelectrnix.com/item_9551_Hifonics+TXi+1008D.html# when you click to see more images. Except for the level which I set to around 4 because I have 4v preamp outputs.
Thanks in advance for any help
Posted By: clementi
Date Posted: August 27, 2008 at 7:44 PM
actually it's a kdc x591 headunit, my bad
Posted By: i am an idiot
Date Posted: August 27, 2008 at 8:14 PM
Define a BIT of smoke.       Chances are the power supply of the amp has went out.   Usually this will produce lots of smoke.  Some occasions not so much smoke.  If Sonic offers any kind of warranty on their products you really need to send it back to them.   It could cost near as much as you paid for it to get it repaired.
Posted By: clementi
Date Posted: August 28, 2008 at 9:52 AM
I mean like my trunk wasn't filled with smoke, there was probably about the same amount as if you lit half a  sheet of paper on fire. What did I do wrong though or was it defective?
Posted By: DYohn
Date Posted: August 28, 2008 at 9:53 AM
I love posts like this.  "Hey, my amp is smoking, do you think there's something wrong?"  Yes, there is something wrong.  Please go to a professional installer and get your system checked out and installed correctly before you burn the car down.  Thanks.
Date Posted: August 28, 2008 at 11:25 AM
I have no idea if the amp was defective or if there was a problem with the install.  We were not there to inspect the install.  With that much smoke, the power supply is out and possibly shorted output transistors caused it.   It will be expensive to repair it
Posted By: clementi
Date Posted: August 28, 2008 at 1:47 PM
Sorry for trying to get into a new hobby.
I obviously know that something is wrong, I just wanted to know if anything jumped as a problem. Never mind though, I'll get help elsewhere.
Posted By: DYohn
Date Posted: August 28, 2008 at 2:18 PM
like I said, please go get some assistance from a pro in your area.  Thanks.
Posted By: KarTuneMan
Date Posted: August 29, 2008 at 12:34 AM
smoke = bad!
You installed it, it smoked.... get some help. simple.
Posted By: haemphyst
Date Posted: August 29, 2008 at 6:59 PM
A perfect example of someone letting the magic smoke out. Can't put it back in!
Date Posted: August 29, 2008 at 7:03 PM
 It can be put back in, it is just costly in those amplifiers.       Not many people understand that amps run on smoke.  They are all under the false impression that they run off of electricity.  This is not true.  The reason I know they run on smoke is that, if you let all of the smoke out, they quit working.
Posted By: megaman
Date Posted: August 29, 2008 at 8:33 PM
lol, my professor used to tell us that all the time.  "they run on smoke, if  you let the smoke out, they quit working." lol
