98 deville aftermarket head unit
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107732
Printed Date: April 11, 2026 at 11:49 AM
Topic: 98 deville aftermarket head unit
Posted By: ryder_hayabusa
Subject: 98 deville aftermarket head unit
Date Posted: September 26, 2008 at 4:51 PM
tried to use the 32 pin wiring harness, was working but would lose memory, and factory alarm would go off sometimes when i would go to start it. and the key fob wouldnt work sometimes with it hooked up. i know that i should have used the gmrc-03 but was expensive, and now look at what i have myself into. i was told that i could make the 32 pin work and which i had but the memory and alarm acting up, has anybody heard of this?
Posted By: still_walkin
Date Posted: October 01, 2008 at 6:42 AM
sometimes this happens with devilles with you take out the facotry hu. you lose your chimes and the factory alarm goes weird. did you use a metra harness on the new hu or you splced the old wires on the factory harness
1993 sdv
Alpine 4x6 6x9 5 1/4 swr-10d4
alpine v60
12.5 VGA flip down
Nettop pc w/10" touch screen
78nova
5-re audio 5x7 ,10" sub &
Xtx-500.5
Date Posted: October 01, 2008 at 5:39 PM
32 pin metra harness
