wattage vs cone area
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107938
Printed Date: April 09, 2026 at 5:49 AM
Topic: wattage vs cone area
Posted By: dangerous10k
Subject: wattage vs cone area
Date Posted: October 05, 2008 at 9:56 AM
here is my question
alright if you have 1 5000 watt sub how is it gonna sound compared to 2 2500 watt subs vs 4 1250 watt subs?
im just thinking one 5000 watt sub should be significantly louder because 4 1250 watt subs are not 5000 watts they are 4x1250
Posted By: DYohn
Date Posted: October 05, 2008 at 10:10 AM
No. One speaker receving 5000 watts (assuming there was a speaker that could handle 5000 watts) would theoretically produce the exact same dbSPL as four of those speakers receiving 1250 watts each. Double power = +3db. Double cone area = +3db. If one speaker @ 1250 watts = 100db, then 4 speakers @ 1250 watts = 106db, or one speaker @ 5000 watts = 106db. ------------- Support the12volt.com
Date Posted: October 05, 2008 at 11:34 AM
so triple the cone area will be another 1.5db over double the cone area?
Date Posted: October 05, 2008 at 11:39 AM
I have to Kicker CVX 12's and im thinking about switching to 2 soundsplinter rl-p12's vs 1 sound splinter rl-s15, i want something that has some soundquality but at the same point i want spl to
Posted By: aznboi3644
Date Posted: October 05, 2008 at 11:52 AM
with 5000 watts going to one speaker..I'd say the four speakers would be louder...less power compression with four coils splitting the power vs. one.
Posted By: haemphyst
Date Posted: October 05, 2008 at 2:55 PM
Kicker? Soundsplinter? SQ doesn't belong in the same paragraph with those brands... There are MANY other woofers out there that will do SQ first and still split your head open with adequate power! ------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
Posted By: ragsports
Date Posted: October 05, 2008 at 5:31 PM
Wouldent it also depend on the sensitivity of the woofers.. for example if the single 5000 watt speaker had a sensitivity of 84 db and the 4 speakers receiving 1250 watts was lets say 90 db, wouldent the 4 speakers be louder because of a higher sensivity rating? Im not sure if this is right ,clear me up if i am wrong i was just pondering on this idea after reading the question earlier in the day...
Date Posted: October 05, 2008 at 7:28 PM
All sensitivities being equal to begin with... Otherwise, yes, you are correct.
I believe that DYohn actually used in his example the same woofer, but one in a 5000 watt install or four in a 1250 X 4 installation.
Same sensitivity, 1 X 5000 will be the same output as four of the same woofer in a 4 X 1250 configuration.
Date Posted: October 05, 2008 at 10:02 PM
I have kicker i realize they have crappy sound quality what is a sub that does have good sound quality? someone was saying tc sounds in another thread but where do you buy tc sounds subs?
Date Posted: October 06, 2008 at 12:48 AM
i have a jbl gto 14001 which is rated at 1200 rms @ 4 ohms i believe, (probally aint true according to you're amp selection thread) it has 4 40amp fuses, its in a 04 mustang gt which i believe has a 120 amp altenator, i have 0 gauge power wire going into a distrubtion block with 4 gauge to the amp and 8 gauge to the 4ch
I want spl and sound quality,or at least something that has better sound quality than my two 12" kicker cvx's
Date Posted: October 06, 2008 at 8:09 AM
Parts Express. On the left, click the drop-down shop-by-brand menu, and select "Audiopulse". Audiopulse is what TC became. ------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
Date Posted: October 06, 2008 at 9:12 PM
thanks for the link i gotta another question here trust me ive already looked at the enclosure link but does a sealed box hit lower than a ported cause i got a ported box, and my friend has a sealed box with 2 15" kove audio subs and only like 600 rms and his hits lower than my 2 12's with 1500 rms in a ported, he has a rockford fosgate amp i got a jbl is it my subs the box or the amp why does his hit lower notes just because he has 15s you can really here the difference on bass i love you, i would say mine diffenetly has better sound quality and is louder but has less spl
Date Posted: October 06, 2008 at 10:16 PM
Your friend has about double the cone area
This is probably a case of "there is no replacement for displacement"
Date Posted: October 08, 2008 at 9:15 PM
size wise how big is a boston acoustins 555 a 15?
