10 w6v2 in ho110r enclosure
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108062
Printed Date: April 11, 2026 at 6:29 PM
Topic: 10 w6v2 in ho110r enclosure
Posted By: itsmejaytee
Subject: 10 w6v2 in ho110r enclosure
Date Posted: October 10, 2008 at 1:10 AM
okay so i have a 10" w6v2 in HO1104 enclosure with a kenwood kac-x1r amp pushing it.
do i need to poly fill this enclosure? and i was told not to plug up the ported openings?
also im not sure how to tune this set up. my amp has settings for BRF LPF ISF. right now i only turned on the LPF to about 60hz and it sounds decent. how do i use the other settings effectively?
any tips at all on my set up would be much appreciated
Date Posted: October 10, 2008 at 1:18 AM
oops typo, its a HO110R not HO11O4. its the high output wedged box from JL
Posted By: tcss
Date Posted: October 13, 2008 at 8:15 PM
Do not use any polyfill in the enclosure. The lpf is fine at around 60hz, but just for fun try it at 70hz and 80hz. Listen to it a see how you like it. Turn on the ISF ( infra sonic filter) and set it to 20hz. Leave the BRF off. Enjoy
------------- There is no such thing as free installation!
