amperage meter for system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108078
Printed Date: May 02, 2026 at 7:27 PM
Topic: amperage meter for system
Posted By: carlcom
Subject: amperage meter for system
Date Posted: October 10, 2008 at 6:03 PM
I have a LED voltage display ready for my dash and would like to add an amp display.  I have 0 gauge from the battery to the trunk.  I guess an Amp meter could measure the voltage difference and knowing the resistance of the 0 gauge, figure the amperage.  Or an inductive clamp like the Fluke 321 meter.  I'd rather not home build something but haven't seen anything for sale.  Class AB rated 2500 watts means about 350 amps.  Any ideas how best to do this?
Anyone know how the Soundstream capacitors measure it?
posted_image
Posted By: haemphyst
Date Posted: October 10, 2008 at 7:11 PM
It's calld a "Shunt Resistor", and they will be rated in a given current range. Basically you then connect a VERY sensitive voltage meter across the ends of it, and measure the voltage drop across it. They are generally rated at X millivolts, at X current, so you will match your meter to this mV drop for X current. They are generally PRECISION devices, rated for tremendous current, as are the meters associated with them. I will locate some links, and post them for you.
Here's a really good explanation...
Posted By: forbidden
Date Posted: October 11, 2008 at 4:10 PM
If this is the same person who posted on CCA, here is the same link I gave there.
https://www.dakotadigital.com/index.cfm/page/ptype=results/Category_ID=243/home_id=59/mode=cat/cat243.htm
Posted By: carlcom
Date Posted: October 11, 2008 at 5:38 PM
Thank You for the Dakota Digital link!  The Solarix series is almost exactly what I was hoping to find.  I bit big but I'll make them fit, won't be the first time.  It doesn't use a shunt so I won't have an extra .15V drop.  And they're not made in China, a plus to me.
I'm thinking of getting the voltage meter to match and maybe the temp meter.  Doing my part to help the economy!
