subs not as loud as they should be
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108756
Printed Date: March 27, 2026 at 3:07 AM
Topic: subs not as loud as they should be
Posted By: darkkon
Subject: subs not as loud as they should be
Date Posted: November 08, 2008 at 9:59 AM
https://www.online/CarAu...roductid=17397
https://www.pioneerelectronics.com/PU...er/DEH-P3000IB
https://www.online/CarAu...roductid=12982
https://www.online/CarAu...roductid=19123
with a sealed box, subs wired at 2 ohms.
80 amp AGU fuse and the fuse on the amp is three 25 amps so no problem with the fuses there.
if i turn the headunits volume up to about 30 they start getting louder but thats way to high for the speakers and they distort. the speakers in the car are 4 ohm. and they are 4x6 with two tweeters in front.
93 nissan pathfinder, enclousure is sealed and in the trunk facing the back
i checked all the settings on the headunit and the amp, i turned all of them up all of the way and they still arent even hitting nearly as hard as i had them, they are very quiet and should not be this quiet as i have had installed them in a different car and have had them actually running where you could hear them, you can barely hear them and they are moving a little bit.
Posted By: DYohn
Date Posted: November 08, 2008 at 10:30 AM
Sounds like you may have one sub out of phase with the other. Check your wiring. ------------- Support the12volt.com
Posted By: ckeeler
Date Posted: November 08, 2008 at 10:41 AM
i thought the same thing too until i read where he said they are barely moving. do you still think it could be they are out of phase?
Posted By: darkkon
Date Posted: November 08, 2008 at 10:52 AM
no, i took them straight from my old car and they worked perfectly then. the pos is on the pos and the neg is on the neg
Posted By: ckeeler
Date Posted: November 08, 2008 at 10:58 AM
he means the way they are wired together in the box. not how they are hooked to the amp
Posted By: darkkon
Date Posted: November 08, 2008 at 11:03 AM
yes, in the box they are fine and to the amp they are fine.
Posted By: DYohn
Date Posted: November 08, 2008 at 12:35 PM
Then either your speakers are blown or the amp is blown - or perhaps just set up incorrectly. How is your LP filter set and did you set the gain correctly? ------------- Support the12volt.com
