best setup with 2 kenwood subs?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109037
Printed Date: April 18, 2026 at 11:07 PM
Topic: best setup with 2 kenwood subs?
Posted By: wolfpack557
Subject: best setup with 2 kenwood subs?
Date Posted: November 18, 2008 at 8:58 PM
Ok, I have (2) dual voice coil kenwood subwoofers that have impendance of 4 ohms. I curently have both subs ran in parallel, and then phased wired from the box to the amp. ( 2 channel) here is the stats of my amp as followed:
  • 170 Watts RMS X 2 At 4 Ohms (250 Watts X 2 At 2 Ohms)
  • 500 Watts RMS X 1 Bridged Output At 4 Ohms
  • Can someone tell me the best way to wire these that will make it pound lol
    Posted By: haemphyst
    Date Posted: November 19, 2008 at 8:56 AM
    "Best setup with two Kenwood subs", huh? That's like asking what's the best way to eat a handful of poo. Kidding.
    Wire the woofers in series, for 8 ohms, then wire them in parallel to the bridged amplifier. This will provide you with the 500 watts the amp is rated for, and 250 watts per woofer, which I think is what you already have... I don't understand "phased wired", but you said (2 channel), so I am assuming that you don't have it bridged presently.
    Since you didn't provide any model numbers, I can only assume that you have already checked that the amp is respectable, and can actually DO 500 watts, bridged into 4 ohms, AND that the woofers are actually capable of handling 250 watts RMS, each.
    Date Posted: November 19, 2008 at 8:55 PM
    yea phased wiring as in the positive go to the positive negative to negative from box to amp (2 sets of wires in two channels) not bridges, and the model numbers are as follows
    amp - kac-7203
    subs(2)- kfcw3514dvc
    Date Posted: November 25, 2008 at 6:54 PM
    ok i have two kenwood dual voice coil subwoofers that are 4 ohm impendance each.  I have a kac-7203 and a kac-8104d amp i want to run 1 subwoofer to each amp for maxium power.  someone please help.  the class d amp is a 1 channel amp but it has speaker ports liek this ++-- i dont know what to do with this because it says 500 rms at 2 ohms but i have no clue how to run one speaker that is 4 ohm impendence to 2 ohms.
