can anyone make a custom adapter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109137
Printed Date: April 26, 2026 at 6:37 PM
Topic: can anyone make a custom adapter
Posted By: CBR629
Subject: can anyone make a custom adapter
Date Posted: November 22, 2008 at 6:38 AM
I need a 6x8 hole for a 8" opening.I have 2 8" speakers in the rear of my car deck and I want to put 6x8's there but i'm not good with fabricating.I just need a set of rings and I will pay with paypal account
------------- THANKS
Posted By: DYohn
Date Posted: November 22, 2008 at 12:09 PM
Wow, if I had 8" openings in the rear deck a set of 8W7's would be in them... what vehicle are you driving? ------------- Support the12volt.com
Posted By: i am an idiot
Date Posted: November 22, 2008 at 6:57 PM
It would not be really considered fabricating. Remove the 8 inch woofer, place it upside down on a piece of 1/4 inch MDF, trace the outside of the woofer. The 6 x 8 speaker should have a template with it, place that in the middle of the traced circle of the woofer and mark it. Drill a hole in the middle of the 6 x 8 hole. Using a jig saw cut the 6 x 8 hole out. Now cut the 8 inch hole. If you are not comfortable using the saw, draw it and I am sure you know someone that can do that for you.
Posted By: reax222
Date Posted: November 24, 2008 at 1:31 AM
Would 1/4 MDF stand up to regular driving/heat/moisture? I would be afraid MDF that thin wouldn't last long.
Date Posted: November 24, 2008 at 1:54 AM
I live in Louisiana, here it is not called moisture, it is Humidity. We have tons of that, we will not mount an overhead in MDF (for other reasons) but we use it for speaker adapters and spacers all day. I have never seen or heard of a problem using it. But if he feels better, some 1/4 inch plywood will work just as well.
