alpine mrd m500
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109217
Printed Date: April 23, 2026 at 10:39 PM
Topic: alpine mrd m500
Posted By: thenney
Subject: alpine mrd m500
Date Posted: November 24, 2008 at 8:41 PM
does anyone know how to get the E3 code off of my amp...this code said in the manual,that the amp is in shut down mode...due to excess current,now I installed the amp yesterday,no problems...then today,I was messing with all of the modes...setting up crossovers,etc...then the amp just shut off,r went into protect mode...I have ma audiu 4 channel amp,plus a 3 farret cap...any idea of what I can do....I am getting 13.7 to 14 volts at the amp....when the car is running,and you turn the stereo on you can hear the car idle go up for a second????please help,I am about to throw this amp in the trash
Posted By: KarTuneMan
Date Posted: November 25, 2008 at 11:53 AM
What did you attach to the amp? due to excess current not a good thing. plus a 3 farret cap beware, farret's have sharp teeth! -------------
Posted By: thenney
Date Posted: November 25, 2008 at 12:30 PM
I have 4 gage power,120 amp fuse,cap.then that is feeding the amps...LIke I said, I had no problem when I first hooked everything up...then when I started to mess with all the modes...thats when in stop putting out sound...still have power...but it read in the display e3...I have since removed the cap...still the same problem....help please....the last time I had alpine I had problems with there amps....MAYBE,I SHOULD HAVE STAYED AWAY!!!!!
