DB Drive Or Kicker?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109218
Printed Date: April 23, 2026 at 9:07 PM
Topic: DB Drive Or Kicker?
Posted By: ernk29
Subject: DB Drive Or Kicker?
Date Posted: November 24, 2008 at 9:05 PM
which one's better?
posted_image
Kicker 06CVX10-4
rms 600watts
max 1200watts
Resonance Frequency: Hz 33.6
Total Q-Factor: 0.376
Equivalent Volume: 1 ft3
Driver Sensitivity:87.2db
posted_image
DB Drive platinum pt10d4
rms 600watts
max 1200watts
Resonance Frequency: Hz 34
Total Q-Factor: 0.43
Equivalent Volume: 0.78 ft3
Driver Sensitivity:83db
Posted By: aznboi3644
Date Posted: November 24, 2008 at 10:28 PM
no sub is better than the other
Posted By: haemphyst
Date Posted: November 24, 2008 at 10:36 PM
And both of those are big shiny turds, anyway.
What is your ultimate goal? SPL or SQ? I'm betting money on SPL, if those are the products you are asking after...
Posted By: 98neonr/t
Date Posted: November 24, 2008 at 10:39 PM
the question shouldn't be wich sub is better you should ask wich sub is best for this application. but if you are asking wich sub is more efficent than it looks like the kicker is more efficent and it is more redily avalable and if you live near an electronic express you can get the kicker buy one get one free.
Posted By: ernk29
Date Posted: November 25, 2008 at 10:00 PM
well my sealed enclosure is 0.6cu.ft. which is exactly what the DB drive, the kicker needs 0.8cu.ft. atleast but i think think insulation could be used to compensate. And i have an Alpine MRP-650 whic runs 600rms at 2ohms, so it matches either sub. what is total q-factor and Equivalent Volume? And has anyody heard DB drives before?
Posted By: ernk29
Date Posted: November 25, 2008 at 10:12 PM
As for SPL, how hard would one ten cvx hit?
Posted By: soundnsecurity
Date Posted: November 26, 2008 at 6:47 PM
139.6db,..... but only if the windows are down half way.
for a 10 they hit pretty good, it looks like the kicker might have a little more cone area than the DB drive
