2000 dodge stratus, stereo, wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109458
Printed Date: April 22, 2026 at 11:31 AM
Topic: 2000 dodge stratus, stereo, wiring
Posted By: wizzle2282
Subject: 2000 dodge stratus, stereo, wiring
Date Posted: December 03, 2008 at 9:20 PM
i have a 2000 dodge stratus with a self installed stereo system consiting of a sony cdx300 stereo/cd kenwood kac-7203 bridgeable 1000w 2ch amplifier a rockfordfosgate 1 farad capacitor and 2 15" xsite dual 4 ohm voice coils everything works proplerly but when i use turn signals, turn on A/C, turn on high/low beams, use dome light, role down a window or open a door etc the stereo and the secondary amp cuts out for 1-2 seconds and cuts back on and will continue to do so untill i have turned the componet off(A/C turn signal etc). could it be the bad ground wires do i need a bigger battery i have no idea to witch the problem is caused maybe bad fuses any suggestions would be appreciated.
Posted By: xplorin16
Date Posted: December 03, 2008 at 9:26 PM
I would definitely reground it and go from there. ------------- Advanced MECP
Posted By: ragsports
Date Posted: December 03, 2008 at 10:17 PM
Seems to me like it is a voltage problem, measure the voltage across the terminals of the amp when it is cutting out and lets us know what it is. Also read the sticky of upgrading your big three this will help out with the voltage issue if thats whats causing your amps to cut out.
Posted By: boogeyman
Date Posted: December 04, 2008 at 5:52 PM
X2 ragsports
